Activity › Forums › Sony Cameras › EX3 New Lens Suggestions?
Posted by Martin Phillips on May 28, 2009 at 8:41 amOk, so have been struggling to do smooth zooms using the supplied lens,(even with a remote controller) and have noticed from these boards that this seems to be a common problem. So it looks like a proper replacement lens is needed.
I have narrowed my lens search down to 3 lenses:
Canon KH20x6.4KRS
Fujinon XS17x5.5BRM
Canon KH13x4.5KRS (Wide angle)Does anyone have experience / suggestions for any of these – or alternatives?
Thanks – Martin.
Olof Ekbergh replied 17 years, 3 months ago 5 Members · 8 Replies -
Olof Ekbergh
May 28, 2009 at 11:01 amSony replaced my lens about 6 months ago and it has been very smooth ever since then.
I wold insist on a replacement.
I would choose Canon KH20x6.4KRS as a second lens because I could use a longer lens than standard.
If you do get a second lens send the original back to Sony and insist on a replacement.
Olof Ekbergh
David Issko
May 29, 2009 at 5:16 amI bought the XS 17×5.5BRM lens when I bought the camera. Not only do you have superb control over zoom speed & smoothness, but the better ergonomics of the lens and setup lends itself to a better hand holding/semi shoulder mounting experience, which, in my opinion, offsets from the added weight to the front.
I also have the VF Gadgets reinforced base plate and connected to it is my radio mic receiver which adds a little weight at the back.
Martin Phillips
May 29, 2009 at 7:49 amThank you Olof and David.
I have seen lots of positive comments about the Fujinon XS17x5.5BRM, so will probably go with this. Presumably, David, I just use the supplied adapter (which came with the camera) and off I go? Does the power for the zoom servo etc. come through the internal connections on the outside of the lens (like on the supplied lens)? Also, presumably I can plug a normal remote zoom demand into the usual place under the lens?
Thanks – Martin.
Ed Kukla
May 29, 2009 at 10:24 amAs I understand it, the supplied lens adapter does not provide any connections to the electronics. Fuji makes an adapter that has a connector to jump the camera to b-4 mount lenses. It costs over $1500.
Olof Ekbergh
May 29, 2009 at 11:40 amThe supplied adapter is for 1/2″ glass it does power lens from contacts on mount, for lenses that have contacts on mount.
2/3″ lenses that require external cable need the Fuji adapter.
Olof Ekbergh
Martin Phillips
May 29, 2009 at 11:44 amYes, my adapter has connections on both sides. So hopefully this should go straight into the XS17?
Harry Newman
May 29, 2009 at 4:31 pmThere is no way the EX3 lens is suppose to be jerking. I have often had trouble over a zoom of 10 (at 13, 16, even 18 speeds). Sony needs to fix this! They know it’s a common problem. But they want me to send in the camera that I depend on day to day to make a living. I have a hard time being without it for possibly two or three weeks to fix.
I am going to continue contacting them, until a reasonable solution is reached. I suggest others with this problem do the same. There may be many more users out there that have no idea the zoom is defective. Call and write Sony… that’s what I am doing.
Olof Ekbergh
May 30, 2009 at 11:33 amMy dealer (I have been using him for over 15 years now) lent me another 1/2″ lens a Fuji 17x while he raised heck with Sony and I had a brand new lens within 2 weeks. I had full use of the cam the whole time.
This was about 8 months ago when Sony did not have enough of the lenses to ship new cams.
Thanks Kevin.
Talk to your dealer.
This is why I always use a dealer when buying expensive equipment, not a “super WEB store”.
Olof Ekbergh
