Activity Forums Apple Final Cut Pro Legacy EX3, Multicam, Logging, Synching
  • EX3, Multicam, Logging, Synching
    Posted by Ed Mccarthy on July 14, 2009 at 7:59 pm
    Greetings,
    I have a few questions related to a project I am preparing to edit. It has been some time since I’ve had to tackle these sort of technical concerns, so I’m a little rusty, and some of this stuff is just new to me.
    We have a documentary that was shot on the EX3. Field capture of the cards was handled as described elsewhere on this site, using shotput pro to hard drives, etc. During the shoot, we had two cameras running simultaneously, and 18-20 channels of individually recorded audio, all of which was recorded using the same time code via some sort of box/ generator.
    Now we’re ready to start logging/ capturing/ synching.
    1) At what point do we sync the audio to picture? Due to the nature of the shoot (many individually mic’d people in a large room), I doubt a detailed log can really be made until we have the audio tracks synched up with picture (onboard camera mic is often useless). On the other hand, don’t we need to break the clips up individually in LOG/ CAPTURE just to get them into the system? (In the past, I’ve always cut using camera audio and saved the synching for after picture lock.)
    In other words, we’re dealing with 8-10 hours of footage per camera, per- day, in one room using the same individuals. I’m not sure it’s going to be obvious to the assistant editors where to split the footage into individual clips without all the audio tracks, because a lot of it will have to do with what subjects are saying on- screen.
    Should they import entire cards of footage as single clips, synch them, and then sub-clip?
    2) In the past, I’ve had assistants build a detailed log in EXCEL for eventual import into FCP. Are there any issues associated with this pathway given that the footage is card- based, as opposed to on tape?
    3) How clunky is FCP editing going to get with 18 audio tracks in the timeline? Should I consolidate to fewer tracks? The editing station is a brand new quad core (2.66) with 8 gigs of RAM, and I’ve never dealt with this many tracks of audio from start to finish in FCP.
    Thank you very much for your replies.
    -Ed
    Michael Sacci replied 17 years, 2 months ago 2 Members · 1 Reply
  • Michael Sacci
    July 14, 2009 at 10:30 pm
    How is your audio going to be masters. I work in live concert a lot and we get a rough stereo mix to edit with. While we are editing audio is mixing all the audio tracks. In the end I give him a timecode burn of the final edit and he conforms audio to picture. So I’m always only working with stereo audio (he records up to 96 tracks).
    For the footage I would set up the longest length clips as possible, make the multi-clip and then just set different Ins and Outs for shorter sections to work on. If you have solid TC that matches on all the cameras you pretty much can do whatever you want since you can sync by TC, so there is no right or wrong here, just what is most comfortable for you.
