Activity Forums Apple Final Cut Pro Legacy EX3 media flickering in FCP
  • EX3 media flickering in FCP
    Posted by Rudy Shalamar on August 31, 2009 at 4:03 pm
    I shot some interviews in a controlled environment (small photo studio) with the EX3 HD1080 30p and all was well but now that I’ve imported them into FCP there is a strange flicker, almost pulsating, color shift happening. When I play the footage back in the camera all is well and when I play the footage in the log and transfer window the footage is fine.
    It seems to be only happening in FCP.
    Is this a common problem and is there a solution for this?
    Thank you!
    Da Ri replied 15 years, 4 months ago 4 Members · 3 Replies
  • Chris Borjis
    August 31, 2009 at 4:14 pm
    what happens when you play them through quicktime?
  • Arnie Schlissel
    September 1, 2009 at 2:08 am
    If the room was lit with fluorescent lights, that’s typical. It’s also a problem. Take a look at the Furnace plugins from the Foundry. They have a flicker plugin just for this kind of thing.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Da Ri
    May 24, 2011 at 2:10 pm
    I noticed this same issue on my system, I did a test export and it came out clean… Have you found out what causes it to pulse within FCP?
