Activity Forums Sony Cameras EX3 & Firestore & 35mm Adapters
  • EX3 & Firestore & 35mm Adapters
    Posted by Mark Espina on September 16, 2008 at 1:49 pm
    Hi!
    Two questions:
    1) Can you use a Firestore with the EX3?
    2) Can you mount a 35mm lens adapter (mini35, letus, brevis, etc….) straight onto the body of an EX3?
    Cheers.
    Mark Espina replied 18 years ago 2 Members · 2 Replies
  • Scot Lenter
    September 16, 2008 at 2:24 pm
    Mark,
    The portable hard drive that can be used with the SxS format is the Sony PHU-60K. It is a 60Gb hard drive.
    I don’t know that you can attach a 35mm adapter to the body of the EX-3 but you can get the 77mm adapter and attach one to the end of the lens, same as you would on an EX-1.
    Scot Lenter
    Midtown Video
    Miami, Florida
    Service Manager
    Rental Agent
    scot@midtownvideo.com
    305-669-1117
  • Mark Espina
    September 17, 2008 at 1:51 am
    Hey Scott,
    Thanks for your reply.
    The PHU-60k is indeed what I was looking for.
    Regarding the 35mm adapter connecting straight to the body of the EX3, I got that idea after finding this in vimeo:
    https://www.vimeo.com/1542171
    And was answered in an article I found when I went to look for info on the PHU-60K.
    Apparently Letus is creating a 35mm adapter to fit straight onto the body of the EX3. You can read the artilce here:
    https://www.dvuser.co.uk/content.php?CID=174
    Thanks again.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
