Activity › Forums › Apple Final Cut Pro Legacy › EX3 720p24/60 not playing slow mo?
  • EX3 720p24/60 not playing slow mo?
    Posted by Aj Koch on June 28, 2010 at 5:06 pm
    I asked my camera operator to shoot some slow-mo overcrank shots at 720p24/60. Now I’m in edit, and Log and Transfer brought in the overcrank shots at 720p59.94. The bit rate is 35Mb/s.
    Now, correct me if I’m wrong, but doesn’t shooting 24/60 crank up the bit rate to 85Mb/s? If so, did my shooter just shoot at plain 720p60? Because Final Cut is playing back these clips at normal speed, despite dropping them into my 23.98 timeline.
    I have figured out that I can change the codec on these 60p shots and convert them to 23.98 in Cinema Tools, but my understanding is that A) I SHOULDN’T HAVE TO do this, and B) my bit rate is less than optimal, resulting in less than optimal slow-mo picture.
    So did my shooter screw up? Or am I importing this footage wrong?
    Any help, info, or advice would be appreciated.
    -Aj
    Rafael Amador replied 16 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 28, 2010 at 5:32 pm
    [Aj Koch] ” If so, did my shooter just shoot at plain 720p60? Because Final Cut is playing back these clips at normal speed, despite dropping them into my 23.98 timeline. “
    Just dropping 720p60 footage into a 23.98 timeline doesn’t instantly make it slow motion. No, what that will do is play normal speed, with frames removed. And doing the speed change (CMD-J) won’t do the proper speed change either.
    To make this footage slow motion, you need to convert it to a non-GOP format, like ProRes (because you can’t perform this operation with GOP formats), and use CINEMA TOOLS to CONFORM the footage to 23.98.
    Shane
  • Aj Koch
    June 28, 2010 at 6:37 pm
    Ahhh works perfectly! Thanks!
  • Rafael Amador
    June 29, 2010 at 1:48 am
    If the footage doesn’t play in slow motion is because your cameraman did it wrong.
    When you record 720p20/60, you end up with a p24 file (slow motion) without audio.
    As you points, the file is recorded at around 85Mbps, but on play is standard 35 Mbps.
    rafael
    http://www.nagavideo.com
