Activity Forums Sony Cameras EX1R tripod advice
  • EX1R tripod advice
    Posted by Scott Morrison on January 7, 2010 at 9:07 pm
    hey guys,
    i just recently got an ex1r and have been using a crappy velbon tripod that i had from my hv30 days. since i film snowboarding i used it to get me by for the first couple shoots because it was small and light, this was key since well hike up to four hours in waist deep snow to get to a spot or jump and always have to ride with it to get down.
    just now ive been able to find time to search for a good tripod since it is a necessity but i dont know too much about higher end tripods. the one ive found that i think would best suit my needs so far has been this.
    https://www.bhphotovideo.com/c/product/523094-REG/Manfrotto_by_Bogen_Imaging__BO055XB503H_055XDB_Pro_Tripod.html#specifications
    im wondering if this one would do the trick for an ex1r
    if you guys have any suggestions for a tripod that folds up small and is somewhat lightweight for the ex1r it would be greatly appreciated.
    -Scott
    Final Cut Studio 3
    Sony PMW-EX1R
    Geoffrey Chandler replied 16 years, 4 months ago 13 Members · 18 Replies
  • 18 Replies
  • Clint Fleckenstein
    January 7, 2010 at 9:29 pm
    If you can swing more money, I think you’ll have much better luck with the Sachtler FSB-6 head. That’s what we got and I want to get a second one. This after reading a LOT of reviews everywhere I could find them. This is the smoothest tripod head you’ll find anywhere close to this price range, for sure. Very important factor to consider if you’re going to be doing any pan/tilt work to follow the shred.
    We put the FSB-6 on a carbon Sachtler tripod (got the two as a pair on B&H) and I’ve used it in some VERY cold temps, but if you’re trying to save money and are worried about the durability in the cold, I’m sure you can find some matching aluminum legs.
    Cf
  • Ron Pestes
    January 7, 2010 at 10:19 pm
    I have the same setup a Clint and love mine. The carbon fiber Sachtler and FSB-6 head are a great combo. Once you use a good tripod you will never go back. I got mine for $1650 total but the aluminum legs are cheaper. Also, mine has just one clamp per leg so it is fast to setup. Not sure if the Manfrotto will be stable enough for the EX-1.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Scott Morrison
    January 7, 2010 at 10:40 pm
    hmm, id probably go with aluminium legs because durability and price are definitely a factor. is the FSB-6 head about the same size as the 503 head? that is as big as id want to go because size is about the biggest factor. As for price id be able to spend around a grand or more. for now though i dont need the perfect tripod for the ex1, anything will seem like a dream compared to what ive been using. Im thinking my best bet is just to go to a store and try some out, see what i like and actually be able to compare weight and size.
    -Scott
    Final Cut Studio 3
    Sony PMW-EX1R
  • Ron Pestes
    January 7, 2010 at 11:35 pm
    The FSB-6 head is much larger but it stabalizes the head much better too. The tripod comes with its own carry bag as well.
    Sony EX-3
    MacBook Pro
  • Scott Morrison
    January 8, 2010 at 2:00 am
    yeah, thats not gonna work for me then, i literally have to be hauling this up mountains with me. i think ill go with the manfrotto head just because of size and price, and like i said it will be more than enough for what i need. Now for the sticks, im wondering if i should go for something a tiny bit beefier for if i ever buy a glidetrack or something of that sort.
    like this https://www.bhphotovideo.com/c/product/496825-REG/Manfrotto_by_Bogen_Imaging_503HDV_351MVB2K_503HDV_351MVB2K_Aluminum_Video_Tripod.html#specifications
    although looking at it now the tripod i posted earlier and this one have about the same weight rating, might be a typo though.
    -Scott
    Final Cut Studio 3
    Sony PMW-EX1R
  • Paul Crowe
    January 8, 2010 at 8:36 am
    My first choice is Sachtler then I’d look into Cartoni. I’ve used manfrotto and Vinten tripods and after using the others have been underwhelmed. Never used an O’connor though.
    My two cents.
    Cheers
    Paul
  • Tom Daigon
    January 8, 2010 at 2:35 pm
    I have 2 Cartoni Focus F101 tripods and they are great. One is used with my Canon 5D / Sony EX3 cameras and the other is apart of my EX FX jib.
    Avid DS/FCP Editor
    http://www.hdshotsandcuts.com
  • Steve Wargo
    January 8, 2010 at 3:48 pm
    That 503 head will work fine and the stix are probably what you need for your application. Go to a local camera store and examine the leg locks. You want durable flip locks, nothing that you have to turn.
    The most important thing is the size and weight. We shoot on a Sachtler head and stix at home but this is not what I have on a sling when I’m getting on a plane. My travel unit is a 503 on 3021 stix. It has to fit in the overhead. And, I can flip the locks with gloves on.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
    Ask me how to Market Yourself using Send Out Cards
  • Scott Hathaway
    January 8, 2010 at 7:46 pm
    I’ve had very little luck with Manfrotto heads. They do not pan or tilt smoothly after a brief lock down. I can highly recommend the Sachtler 18 and Sachtler 20 heads as they are just the right size for the EX-1. It is a hefty head but with maintenance it will last for decades. When you start attaching rails and the Letus and matte box, the Sachtler 18 becomes a tad small, though still useable, but I then prefer a Sachtler 7+7 Studio II.
    _________
    I make movies, not a living.
  • Alan Lloyd
    January 8, 2010 at 8:24 pm
    Most Manfrotto heads are flat-out awful. Far too many of them put the tilt lock on the tilt axis, which is incredibly bad mechanical design.
    I have a client who uses Canon XL’s and they are nose-heavy. They have Manfrotto heads. It’s a bad mix, trust me.
