Activity Forums Avid Media Composer Ex1 uprez ,,, brain melt sorry
  • Ex1 uprez ,,, brain melt sorry
    Posted by Christie Mccormack on August 27, 2009 at 11:42 pm
    Hi
    I’m having a brainmelt today and can’t seem to figure something out.
    The project I’m working on uses Ex1 – we link to ama and then transcode to 15:1 into a 30i NTSC project to save space.
    Now usually sequences go to an online facility to be uprezzed etc …
    but now I’ve got uprez a short sequence for a pitch and I’m having probs.
    I have to uprez to 2:1 NTSC for output onto a DigiBeta
    I’ve duped the sequence. I’ve reindexed the AMA volumes of the cards we need. I’ve relinked all the clips that are in the sequence.
    Now do I have to transcode the clips again to 2:1? Or are the relinked clips linking to the best resolution anyway?
    sorry if this is a bit basic … but I can’t figure it out.
    thanks in advance
    Christie
    Chris Chandler replied 16 years, 8 months ago 2 Members · 1 Reply
  • Chris Chandler
    December 31, 2009 at 7:53 pm
    I assume you figured out a solution for your hang-up by now, but perhaps you will still get an email alert when I post this–
    You describe importing XDCAM EX footage from AMA at 15:1, editing with that imported footage, and then being able to re-link your sequence back to the original AMA footage. Can you tell me how you did that?? I’m running into issues trying to figure out a proper workflow for a feature doc, and the ability to link BACK to original AMA virtual volumes is the missing link, which I can’t figure out for the life of me.
    thanks
