Activity › Forums › Apple Final Cut Pro Legacy › EX1 to SD DVD
  • Posted by Jason Johnson on August 7, 2009 at 7:27 am
    Hey guys, been reading around these forums and there is a wealth of knowledge here. Unfortunately I’m a PC guy and I can get by on a Mac ok but I need your help. My PC gear is currently being shipped to me but in the meantime I have to make due with this Macbook Pro (brand new 2.8 17″).
    My client just wants a simple DVD of just the raw footage I shot on my EX1. I have Final Cut 6.06 installed along with all the other pro apps. I’ve read around the forums and I think the answer has been spelled out for me but its harder for me to digest being a PC user. Any help or instruction would be greatly appreciated. Don’t know 100% my way around macs and its apps yet..
    Here is what I have so far. Open final cut, open a new sequence with the preset of AppleProRes 422 NTSC. I dropped 20 minutes of footage into the timeline and then exported to quicktime movie. IT gave me about an hour estimate for it to finish. Is this about right? Now here’s what I don’t get..What am I supposed to do with compressor? I read I had to drop this into compressor? Why, if FCP is already exporting it out to the settings I need? Also I have about 90 minutes of footage and my client for whatever reason wants it broken up into 4-5 chapters. Is there an easiar way to export all the footage and then break them into chapters within iDVD or DVDSP? or do I have to just keep adding 20 minutes of footage within FCP and exporting them 1 at time to separate video files for each chapter?
    Again, this was all kinda just thrown at me by my client with the assumption of it being easy, like with the click of one button I can burn my ex1 footage to DVD…I’m very overwhelmed at the momenet…Again any help would be greatly appreciated. Thanks.
    Jason Johnson replied 17 years, 1 month ago 2 Members · 5 Replies
  • Ryan Pratzel
    August 7, 2009 at 1:25 pm
    Jason-
    Welcome to Mac. It may seem daunting, but this is actually a fairly simple process.
    1) Put all of your footage into a FCP sequence. (ProRes or XDCAM codec is fine)
    2) Add *chapter* markers in your timeline. (“M” on the keyboad) Then right click on the marker to bring up the marker edit window. Make sure you choose Chapter marker and you can even label it. This way when you export your footage all of your markers are already in the sequence. **If this process gets to be confusing skip it, you can add markers in DVD SP.
    3) Export using COMPRESSOR — Compressor has all of the correct settings to down convert your footage and make it looks its best on DVD
    4) In compressor go through the Compressor settings. This should be a window in the bottom left hand side of the Compressor screen. If has several folders with different types of settings. Choose the DVD folder.
    **When picking the correct setting I would recommend 120minute Fast Encode. This will still give you a good quality DVD it just won’t multi-pass. To use the compressor settings just click and drag both the Video and Audio settings to your File. (This will be above the settings window)
    5) Make sure you set your destination on your file. Right click on the word “Source” and choose your destination.
    6) Click Submit
    For 90 minutes of footage is will take a while. Sit back, relax and watch TV. (You can click on the batch monitor to watch the progress)
    7) When compressor is finished open up DVD SP. If you want a menu, just choose one of the templates and delete everything except for a title and one of the buttons.
    8) In your DVD SP Pallet (Right side) you will see a Video and Audio tab. You need to go to each tab, click the “+” and add your compressed video.
    9) Drag your video to the menu button and select “Add Track” when it prompts you. Do the same thing with the audio.
    That’s all you need to do.
    **If you need to add or move markers in DVD SP click on your video track timeline. You can move the playhead and click “M” to create markers wherever you want them. You can test your DVD by clicking the “Simulate” button. This will play and allow you to test your chapters and menu.
    Hope this helps. I’m sitting here watching video render, so I thought I’d at least share some wisdom.
    Ryan Pratzel
    Executive Producer
    Creative Liquid Productions
    http://www.CreativeLiquid.com
  • Jason Johnson
    August 8, 2009 at 3:26 am
    Wow thanks so much Ryan. Your help is greatly, greatly appreciated. After I read my own post I halfway didnt expect anyone to reply because of all the questions I asked but you totally came through and saved me!
    I was getting a little restless last night (before your reply) so I exported the whole thing to a QT movie because I read elsewhere its not good to directly export using compressor within FCP? So anyway I exported to a .mov using applepro res and the NTSC preset I read from another thread. I’m taking that mov file (26 gigs for 1 hour 22 minutes of footage) and throwing that into compressor with the settings/advice you gave. Is this ok to do it this way? FCP->QT mov -> compressor? Or should I go strait from FCP to Compressor like you sugguested?
    I’m still getting used to my way around Mac apps, for example when I hit submit in compressor I expected something to happen, like a little window with a progress bar but nothing happened hahah..Then I read what you said about the batch monitor..I don’t get why this is but I probably would have hit submit multiple times until I saw something happen..hahaha. Is this so you can still use compressor for other jobs while something is uh, whats the correct term “compressing” ? in the batch monitor?
    Anyway, compressor is just about done..Took about 25 minutes. Not to bad. Now Im about to go in DVDSP for the first time, wish me luck!
  • Jason Johnson
    August 8, 2009 at 5:12 am
    Hey Ryan, I just finished burning the DVD and testing it out on my dvd player. Great success! Thank you so much for your time and answering my questions. All the info you gave me lead to new discoveries and I know my way around the mac and its apps just that much better. Everything came great. Now I just need to get the organization of files and assets going better. Once I burn the dvd, what files/folders can I delete? I’m pretty meticulous about having unnecessary files lying around my HDD. Like what is this PAR folder it created? Can I delete that?
    Anyway, I cant express enough how much of a help you’ve been. Thanks again Ryan!
  • Ryan Pratzel
    August 8, 2009 at 1:50 pm
    You’re welcome. What’s great about the Final Cut Studio is that there is more than one way to do things. Different people have different preferences in how to go about workflow.
    You can go straight from FCP to Compressor. In fact, Apple has improved the output from FCP to Compressor in the latest upgrade. Compressor can now work in the background while you continue to work in FCP.
    Good luck with your project.
    Ryan Pratzel
    Executive Producer
  • Jason Johnson
    August 12, 2009 at 4:22 am
    Hey Ryan one last question..
    Why does it matter what codec or settings you set your sequence up in if you’re eventually going to use compressor to compress it.. For example I have 720p24 footage…Would it matter if I dropped it into a Sequence that was setup for DV (480) or its native XD 720p24? would it make any difference? its all going to be outputted using compressor to make a DVD anyway? is there any advantage to setting up your sequence with higher or lower settings?
