Activity Forums Apple Final Cut Pro Legacy EX1 Sequence Preferences in Final Cut Pro
  • EX1 Sequence Preferences in Final Cut Pro
    Posted by Hugh Fenton on September 4, 2009 at 11:26 pm
    Hi guys,
    I shot on the EX1 (1080 25p) and when I set the sequence settings it doesn’t give me an option for the native settings of the footage i.e. I shot 1080 25p. I can set that in the audio/ video settings (I have the latest version of Final Cut Pro), but the sequence settings only allow for 1080i with square pixels.
    Any ideas for what I should do, essentially I think I’ve shot progressive but final cut won’t let me edit progressive.
    Regards, Hugh
    Rafael Amador replied 17 years ago 3 Members · 5 Replies
  • Rafael Amador
    September 5, 2009 at 1:58 am
    Should do it. I have no problem editing 1080p25.
    Trash your FC’s Preffes.
    rafael
    http://www.nagavideo.com
  • Alex Bluffield
    September 5, 2009 at 10:41 am
    Hi Hugh,
    when you say ‘latest version’ I assume you mean FCP7. I know that in FCP6 there is no 25p option and as you rightly say you should use the 1080i EX codec. All these cameras record 2 fields of video – in progressive mode they just segement them. I believe when you export your timeline – the video will be ‘resegemented’ back to progressive frames.
    Alex Bluffield
    Final Cut Pro Editor
    W: https://www.a2bpostproduction.co.uk
  • Rafael Amador
    September 5, 2009 at 10:54 am
    [Alex Bluffield] ” I know that in FCP6 there is no 25p option “
    I’m with FC 6 and I have 1080p25 and 1080i50.
    There are standard easy setups.
    rafael
  • Alex Bluffield
    September 6, 2009 at 2:55 pm
    Yes there is a 108025p vbr EX option – I’m on 6.05, possibly came in one of the fcp updates?
    Alex Bluffield
  • Rafael Amador
    September 6, 2009 at 4:06 pm
    Not sure if its comes with the SONY Transfer tool.
    rafael
