Activity › Forums › Sony Cameras › EX1 lenses
EX1 lenses
Posted by Steve Green on May 23, 2010 at 7:49 pmHas anyone experimented with removing the fixed lens of an EX1? It would be great to be able to put a PL or DSLR mount on the camera to get more wide angle options.
Pushpanatha De silva replied 16 years, 3 months ago 5 Members · 4 Replies -
Noah Kadner
May 23, 2010 at 11:53 pmIt would be the same effect as if you experimented with replacing one of your own limbs. Not pretty… 🙂
There are lens adapters that will fit *over* the EX1 lens and give you access to 35mm lenses- Letus, Brevis, etc. But unless you’re a mechanical engineer with a fully equipped optical workshop the only effect you’ll achieve by forcing off the EX1’s lens is a broken camera and a voided warranty.
Quite honestly though- something like a Canon T2i/7D/5D Mark II would be a far more simple and cost-effective route to lens interchangeability.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio. -
Sverker Hahn
May 25, 2010 at 1:54 pmNot a good idea.
Those who want other lenses should buy an EX3.
To get more wide angle options without a 35 mm adapter, you can buy a wide angle adapter from Sony or Schneider.Sverker Hahn, Stockholm
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 15″ -
Derek Reich
May 28, 2010 at 2:10 pmThe WA (wide adapters) are the only option for the EX1/1r. Here are some examples of what is available from Century (Schneider) Optics:
https://www.dvinfo.net/forum/sony-xdcam-ex-cinealta/477833-century-wide-adapters-comparison.html -
May 30, 2010 at 1:49 amHi
There is a wide angle lense made by Sony for EX1 without remving any lenese u can connect that. Model NO Is VCL-EX0877 the cost is A$630.00 with 0.8 magnification/
