Activity Forums Sony Cameras EX1 Footage Problem
  • EX1 Footage Problem
    Posted by Toby Roberts on March 21, 2011 at 6:11 pm
    A shooter gave me some footage shot with the EX1 in 720×480 SD mode, 59.94 fps. I can see the footage in XDCAM Browser, but cannot see it in XDCAM Transfer. Final Cut cannot import using Log & Transfer either. I have the SxS cards, and have copied them to a separate drive. I want to use XDCAM Transfer to export Quicktimes in order to edit in FCP, but am having no luck at all. The media is saved as .AVI files on the cards.
    I’ve never had trouble importing in the past. Perhaps the 59.94 fps is the culprit.
    Any advice or suggestion is welcomed!
    Glenn Student replied 15 years, 5 months ago 7 Members · 11 Replies
  • 11 Replies
  • Craig Seeman
    March 21, 2011 at 6:27 pm
    It must have been shot with EX1R as EX1 does not shot DV.
    These are DV.avi which I believe doesn’t work the XDCAM Transfer or Log & Transfer. You can probably import them directly. FCP will complain because they are AVI but I’ve used DV.avi in FCP without issue.
    Maybe someone else has a better workflow.
    Just a personal aside but what a waist to should DV with such a fine camera. It makes more sense to me to shoot HD and downscale or edit in SD timeline. I just can’t see many reasons to shoot DV.
  • Ian Cook
    March 21, 2011 at 6:53 pm
    Hi Toby,
    Do you have v 1.2 of the plug-in installed for Log and Transfer? It won’t see EX files without it.
    https://www.servicesplus.sel.sony.com/sony-software-model-PDZKLT1.aspx
    “59.94” is the default; it just means 29.97 interlaced (and not 60p). You have two flavors of SD as far as frame rates– 59.94i and 29.97p– and L+T with the plug-in supports both. The same goes for XDCAM Browser. XDCAM Transfer does not support AVIs of any stripe.
    Best,
    Ian
    Ian Cook
    Sony Broadcast and Professional Company
  • Toby Roberts
    March 21, 2011 at 7:11 pm
    Thanks Ian. That updated LT plug in seems to work. I also took the previous suggestion and converted the AVI into QT using Compressor.
    Thanks, I appreciate it.
    Toby
  • Rafael Amador
    March 21, 2011 at 8:04 pm
    [Toby Roberts] ” and converted the AVI into QT using Compressor.”
    You may try re-wrap the AVIs as QT with MPGStreamclip.
    Just “Save as > QT”.
    No transcoding involved.
    If its works, is interesting for you because will be faster than in Compressor, and the picture will save a generation.
    rafael
    http://www.nagavideo.com
  • Toby Roberts
    March 21, 2011 at 9:39 pm
    Great idea! I’ll try that as well.
    Thanks.
  • Sam Cole
    March 21, 2011 at 11:42 pm
    [Craig Seeman] “I just can’t see many reasons to shoot DV.”
    You get a lot more on a card?
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
  • Craig Seeman
    March 21, 2011 at 11:50 pm
    The difference between 25mbps and 35mbps is not a lot in my opinion regarding card capacity. It’s easy to shoot and offload cards too. With two 32GB cards you have close to 4 hours of XDCAM EX HD and you can offload one card in a few minutes while the other is recording if you have a shortage of cards. Unless you’re shooting surveillance video I can’t see much use for the DV codec recording. Heck you could shoot HDV at 25mbps and at least have HD and if you’re just shooting talking heads you might not notice the loss in quality.
  • Olly Lawer
    March 23, 2011 at 3:33 am
  • Rafael Amador
    March 23, 2011 at 9:21 pm
  • Olly Lawer
    March 23, 2011 at 10:32 pm
    Sorry. My post was an error. Tried to delete it but couldn’t.
    Olly Lawer
