Activity Forums VEGAS Pro EX1 footage export for standard NTSC DVD
  • EX1 footage export for standard NTSC DVD
    Posted by James Goodman on March 19, 2008 at 4:23 am
    I shot my first footage with my new EX1 after viewing Vortex Media DVD which suggested shooting in HQ 1080 30p
    my shutter speed was 60 and my footage of beach and panning shots
    I used the Sony clip browser to download my files from the SxS card and export clips as mxf files.
    I am brand new to Vegas since Premiere has yet to catch up on XDcam footage
    I used a DV timeline in Vegas with very simple edits and a couple of transitions then exported to MPEG-2 using the DVD for NTSC Main Concept VBR but set at 2 pass and left the default of I frame 15 etc.
    In Vegas the raw XDcam mxf file footage looked good on my computer monitor
    I burnt a simple DVD using nero
    The footage has jitters on the panning and high rise buildings plus anything with horizontal lines, even the fine stones on the beach appear slightly jitterish.
    Any suggestions on what my Vegas settings should be for the project and the DVD encoding since I will only for now be playing footage on SD NTSC CRT.
    I would appreciate any advice or pointers
    James
    James Goodman replied 18 years, 5 months ago 3 Members · 4 Replies
  • Matthew Roddy
    March 19, 2008 at 9:21 pm
    Hopefully I’m not going against any forum mandates here by posting this link. If I am, I do humbly apologize.
    Forward! I’ve been reading about this very problem on dvinfo.net. I was hoping to see other solutions here. But for your immediate question, check out this thread:
    https://dvinfo.net/conf/showthread.php?t=116587
    They have “solutions” there, but I’m not happy reading any of them (they have to do with small amounts of Gaussian Blur, etc).
    Clearly not everyone is having this problem, so what is being missed???
  • Douglas Spotted eagle
    March 19, 2008 at 9:33 pm
    It’s a bigger issue in PAL land, but adding .001 of Gaus is a common treatment. The sharpness setting in the cam is an issue; many people foolishly crank up crispening, which is a serious mistake for any but the most wide shot, IMO. Doing so will really screw up your image, but many folks don’t see this on their less than stellar displays.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • James Goodman
    March 21, 2008 at 3:30 am
    Thanks for the link Matthew and was I surprised by the number of issues related to HD and HDV as I have been patiently sitting on the fence before jumping into HD. Looks like I may have been premature
    I am playing around with Daniel Alexander’s set of parameters except he is PAL. So far my footage that contains a pan of downtown Vancouver with Lots of horizontal lines on the buildings looks bad. Other pans are just about ok but still any horizontal line shows twitter.
    I would like to know the settings etc that Vortex used for the fabulous EX1 footage on their EX1 training DVD
  • James Goodman
    March 23, 2008 at 1:00 am
    Further to my quest I contacted Douglas Jensen of www. vortexmedia.com
    who produced the DVD “Mastering the EX1” which I found very useful. Douglas sent me his NTSC DVD production workflow as follows
    “”1) I shoot most of my footage 1080 30P HQ — but I don’t think that makes much difference in the final output.
    2) I open a new Sequence in FCP and use the “DV NTSC 48Khz Anamorphic” preset. Or non-anamorphic if the output will be a 4×3 DVD . . . yes, I still do those too.
    3) I change the Field Dominance to “NONE”
    4) I edit the entire program within that Sequence.
    5) When I’m done editing, I then Export a QuickTime movie of the Sequence. I choose “Current Settings” and I do NOT choose to “Make Movie Self-Contained”.
    6) I then take that QuickTime movie and bring it into Compressor.
    7) I then choose the Compressor preset for DVD Best Quality and modify a few of the settings (such as bitrate), but nothing major.
    8) After that file is finished rendering, I bring it into DVD Studio Pro and author the DVD normally.
    This is exactly how my EX1 DVD was produced, and it’s the workflow I’ve been using with XDCAM HD for almost two years. VERY SIMPLE. No extra software, no extra rendering, nothing special at all. I do everyting EXACTLY how I demonstrate in the EX1 DVD. “”
    I followed Doug’s method but using Vegas and rendered my test as a quicktime as per above but then used Adobe Encore to transcode and burn the DVD
    Best results so far and renewed my confidence for going forward with HD (still some flicker on horizontals on buildings in distance)
    James
