Activity › Forums › Sony Cameras › EX1 focus issue
  • EX1 focus issue
    Posted by Brian Cass on March 26, 2013 at 6:19 pm
    When shooting a far-away feature outside, such as a mountain in the distance,my Sony EX1 will not focus sharply. Since I am shooting outside, I usually have either ND1 or ND2 on. Is this a backfocus issue that can be corrected using the maintenance menu? I ask this because I am not seeing any out of focus problem as I widen out. It is only when I am zoomed in all the way. I also make sure to keep the iris around 5.6 so it is not starving for light. I do not see the problem when shooting indoors as the distances are not so great. My firmware is up to date as well.
    Many Thanks!
    Brian Cass
    Brian Cass replied 12 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jw Van der vlies
    March 26, 2013 at 7:36 pm
    I have the ex1r and i never use the ND’s because they make the picture very soft. I always use the shutter to ‘dark’ the picture.
    But it’s also possible that there’s a lot of air/fog between cam and mountain that will give the picture a grey overlay.
    Jw.
  • Brian Cass
    March 26, 2013 at 8:28 pm
    Thanks for your post. It is definitely out of focus and not due to atmospheric issues. Your comment about adjusting the shutter as opposed to using the ND filters is interesting.
    Best,
    Brian
  • Jw Van der vlies
    March 27, 2013 at 10:52 am
    Ok very good! I don’t know, maybe the NDs will be sharp when you backfocus with ND on? I don’t know, it’s just an idea, but for me the shutter always does the trick. Enjoy!
  • Don Greening
    March 28, 2013 at 5:33 am
    The very early EX1s had back focus issue differences between the ND clear setting and the two ND filter settings. This was fixed with a subsequent firmware update.
    If you think there’s a focus difference between ND clear and the activated ND filters then you should do the flange back adjustment located in your camera’s maintenance menu. The EX1 lenses are par-focal so you should be able to have a good focus throughout the entire zoom range. Do the flange back routine twice, the first time using ND clear, the second time using one of the ND settings. Note any difference in focus quality. If there is a difference then send your camera in for service.
    Stopping down the iris (a higher F stop number) instead of using the ND filters is definitely the wrong way to go because of deffraction limiting. The more you close the iris the softer the image becomes, especially noticeable with a big zoom in. The maximum F stop on the EX1 lenses (in front of 1/2″ imagers) is apparently F8. The smaller the imagers the less latitude there is to keep deffraction limiting at a minimum.
    If you need to refresh your memory on how to do the flange back adjustment search this forum using keywords such as ‘flange back adjustment’ or back focus adjustment. And whatever you do DON’T use the one for the EX1R camera. That’s a completely different set of instructions on how to implement the procedure.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Brian Cass
    March 29, 2013 at 4:24 pm
    Don,
    Thanks for your input. I am familiar with the backfocus procedure as well as light requirements when shooting. Still, with shooting outside in sun, I am needing to use a ND filter (the other option, which I have not tried is to increase my shutter speed). I will attempt to redo the backfocus and see if it helps.
    Brian
  • Matt Orfalea
    June 3, 2014 at 8:56 pm
    Did it help? Did you send it in for service?
    Thanks in advance!
    Matt
    https://www.youtube.com/orf
  • Brian Cass
    June 3, 2014 at 9:14 pm
    The issue still exists. I have not sent it in to Sony because I cannot go without a camera for 1 month plus. I have to back off from full zoom in order to keep it from going soft. Since other users do not seem to have this issue, I assume it is not a very common problem.
