Activity › Forums › Sony Cameras › EX1 firewire problems
Posted by Bard Gunnerud on January 22, 2008 at 11:42 amI have just got my new PMW-EX1 and is trying to capture through the iLink HDV, but I can’t get the camera to recognize the computer or computer to recognize the camera. The option to activate iLink in the camera menu is disabled and grayed out.
Anyone know if I have to upgrade the FireWire driver to work with iLink HDV. (I’m just using a regular FireWire port that came with the computer.)
Thanks guys.
Bard Gunnerud replied 18 years, 7 months ago 6 Members · 14 Replies -
Craig Seeman
January 22, 2008 at 1:04 pmYou’re not giving enough info for anyone to help you.
Computer is?
OS is?
Capturing how and with what version software?
What codec did you shoot with? -
Bernie Van velzen
January 22, 2008 at 1:41 pmMy camera came with a user manual 😉
Firewire out only works with supported video formats for HDV, so 1080/50i, 1080/60i and 1080/24p.
Good luck!
Job Van nuenen
January 22, 2008 at 2:35 pm…And don’t forget the bitrate has to be 25Mps (SQ)…
Any other setting won’t output through iLink. But why would you want to do that, while you can output faster than realtime using USB, and the simply select and import the takes you like using XDcam transfer..
I’m still not sure why anyone would want to use the fw output, unless you’ve got a shipload of HDV hardware/equipment you want to keep using. In an HD multicam setup with low-cost mixer e.g. I don’t see myself editing “card to tape” in HDV though…
Media100/after-effects/Combustion/FCP/Flint/Flame/Inferno..
Thank heavens; there’s a sign of progress here.. -
Craig Seeman
January 22, 2008 at 2:45 pmThe only reasons I can see shooting 25mbps CBR is if you’re shooting a talking head seminar and such. You know nothing is going to break the codec and you’d like the longer record times on the cards. Even then you’re using the SxS cards and their faster than real time transfer speeds.
I can see using firewire if you’re in the above situation and really prefer to use FireStore or DR-60 hard drive for recording . . . or maybe live capture during such event.
Yves Chauvel
January 23, 2008 at 7:20 amI used the EX1 last week during a training seminar with FCP 6.0.2 and the latest version of XDCAM transfert from Sony (2.0 or something).
Works just fine with USB connection.
Simply do not use Firewire!Hope this may help…
Yves Chauvel
Steve Wargo
January 24, 2008 at 4:52 am[Yves Chauvel] “I used the EX1 last week during a training seminar with FCP 6.0.2 and the latest version of XDCAM transfert from Sony (2.0 or something). “
Did you do a live recording straight from the camera to the computer?
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
Sony EX-1 has arrived and it’s fascinating. -
Yves Chauvel
January 24, 2008 at 7:22 am“Did you do a live recording straight from the camera to the computer?”
We tranfered MXF files stored (previously recorded 3 weeks ago) on the SXS cards to the Mac.
We did the same thing three weeks ago with 6 DPs using two budget handheld HD cameras: The Sony XDCAM EX1 and the “old” Pana HVX200 P2 with different gammas and adjustments.All 6 of them favored the Sony EX1 for 3 main reasons:
– Low light capabilities (at least a 2 stop difference compared to the Panasonic HVX2OO
– Much, much more controls and setting. Much more precise.
– Rotating handgrip and comfort of use.We have not shot greenscreen footage. So, no keying in post to compare the XCAM 4:2:0 and DVCPRO 4:2:2 signals.
Yves Chauvel
Bard Gunnerud
January 24, 2008 at 8:59 amHow do I capture through USB? I use Adobe Premiere CS3 and it doesn’t nativly support USB capturing I think, at least it does not show up as an option. Can I use a plug-in or a certain driver to capture with USB?
Bard Gunnerud
January 24, 2008 at 9:06 amI guess I’m behind, I thought FW was the best option, but then again, we use Adobe Premiere CS3 for price reasons and it always seemed to work well with FW. What do you recomend, capturing straight from the camera with what, or transfer files by USB and then convert the files with what? Premiere does not support the XDCAM EX files directly, the audio is lost, I have to convert the files to some other format it seems. Downloaded a demo of CineForm but it wont convert.
We use Windows.
Thanks.
