Activity › Forums › Apple Final Cut Pro Legacy › EX1 File importing problems
  • EX1 File importing problems
    Posted by Declan Smith on March 11, 2011 at 12:01 am
    I have been given a disk with a bunch of files with the .MP4 file extension. Neither quicktime, fcp, mpeg streamclip or anything can understand the files. However, after being told they came from a Sony EX1 I installed the XDCam Browser, FCP plugin and XDCam Transfer apps. Gone through using the Browser to recreate BPAV and all that. Some files work others dont. Some work in XDCAM then crash FCP on import (7.0.3)
    Even the sony programs can’t deal with all the files. In fact the only program that seems to understand them is After Effects CS5. Drag Drop, file plays and exports to ProRes, no problem,
    What am I doing wrong with FCP / Quicktime, or how can I resolve it? I can do it with After EFfects, but its very manual. I wanted a batch conversion.
    For example, info from MediaInfo Mac for one of the files:
    * * * MediaInfo Mac 0.7.36.0 file analysis report.
    * * * MediaInfo Mac is ©2010 by Diego Massanti – https://mediainfo.massanti.com
    * * * MediaInfoLib by Jerome Martinez – https://mediainfo.sourceforge.net
    Created on: 10 Mar 2011 23:59:49 GMT
    Report for file: PKEX0519_01.MP4
    General / Container Stream #1
    Total Video Streams for this File……………..1
    Total Audio Streams for this File……………..1
    Video Codecs Used……………………………MPEG-2 Video
    Audio Codecs Used……………………………PCM
    File Format…………………………………MPEG-4
    Play Time…………………………………..28s 240ms
    Total File Size……………………………..123 MiB
    Total Stream BitRate…………………………36.6 Mbps
    Video Stream #1
    Codec (Human Name)…………………………..MPEG Video
    Codec (FourCC)………………………………61
    Codec Profile……………………………….Main@High
    Frame Width…………………………………1 920 pixels
    Frame Height………………………………..1 080 pixels
    Frame Rate………………………………….25.000 fps
    Total Frames………………………………..706
    Display Aspect Ratio…………………………16:9
    Video Standard………………………………Component
    Scan Type…………………………………..Interlaced
    Scan Order………………………………….TFF
    Color Space…………………………………YUV
    QF (like Gordian Knot)……………………….0.675
    Codec Settings (Matrix)………………………Default
    Video Stream Length………………………….28s 240ms
    Video Stream BitRate…………………………35.0 Mbps
    Video Stream BitRate Mode…………………….VBR
    Bit Depth…………………………………..8 bits
    Video Stream Size……………………………118 MiB (96%)
    Video Stream Language………………………..English
    Date of Original Encoding…………………….UTC 2009-11-10 17:20:30
    Audio Stream #1
    Codec………………………………………PCM
    Codec (FourCC)………………………………twos
    Audio Stream Length………………………….28s 240ms
    Audio Stream BitRate…………………………1 536 Kbps
    Audio Stream BitRate Mode…………………….CBR
    Number of Audio Channels……………………..2
    Sampling Rate……………………………….48.0 KHz
    Bit Depth…………………………………..16 bits
    Audio Stream Size……………………………5.17 MiB (4%)
    Audio Stream Language………………………..English
    Declan Smith
    https://www.madpanic.tv
    FCS3 / After Effects CS5 / Combustion / Canon 7D / Canon XL2
    Rafael Amador replied 15 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 11, 2011 at 2:14 am
    Hi Declan,
    Happens that the EX workflow is based on re-wrapping these MP4 from the original file structure.
    Moving those MP4 is very easy to corrupt them.
    When the “Clip Browser” doesn’t want to import an MP4 to rebuild a BPAV, there is only one way (that I know) to fix it and will cost you money.
    Lucky you if you can convert them in PP.
    rafael
    http://www.nagavideo.com
