EX1 & EX3 footage from mac into vegas
Joao carlos Schwalbach replied 15 years, 6 months ago 3 Members · 25 Replies
Mike Kujbida
March 2, 2011 at 9:36 pm“Do you happen to know off hand the link or thread name?”
Sure do.
Can’t view XDCAM-EX files“Although, maybe I shouldn’t, because if it works I’ll be sad that I spent the money!”
It happens to the best of us all the time 🙁
Deirdre O’lavery
March 2, 2011 at 9:43 pmBrilliant – thank you kindly =)
“All you need to start an asylum is an empty room and the right kind of people”
~My Man Godfrey
March 3, 2011 at 10:39 amhey, thank you very much for this very useful info.
kind regards
joao
March 3, 2011 at 11:02 amHi gain,
I have installed Fileconvertor 1.6.
I can’t figure out how to use it.
It installed on a folder and the content is one .dll file anad a couple of .jar files.
Can anyone help?thank you
kind regards
joao
Mike Kujbida
March 3, 2011 at 1:52 pmjoao, when I unzipped the file from Convergent Design, I got a file called FileConverter.msi and two PDFs.
I double-clicked the .msi file and the program installed.
Once that was done, I took an SD card that had an MOV file on it, put it into a card reader, plugged it into my computer, ran File Converter, browsed to the folder on the SD card with the file on it, chose a destination folder on my computer, told it to convert and got an MXF file in the destination folder. -
March 3, 2011 at 3:06 pmI can’t run file convertor. it gives me an error and asks me to point to a program to open it.
Maybe it is java related, will check it out ans post back.
thanks
regards
joao -
March 3, 2011 at 4:50 pmI get the error saying:
“Windows cannot open this file:
File: FileConverter.jar”From the FileConverter website:
“Note that with the PC version, if windows reports “Can not open java .jar file”, please install: Java Runtime Environment”.
I have installed it (versions 6 update 24), installed 2 older versions that were on my pc, but still get the same error message. Also tried uninstalling FileConverter several times and nothing.
What else can I try?
kind regards
Joao
Mike Kujbida
March 3, 2011 at 5:14 pmAll I can think of is is to re-boot your computer after installing Java and before installing anything else.
