Activity › Forums › Sony Cameras › EX1 cant focus at far distance
Posted by Eldrin Flores on February 21, 2010 at 7:38 amWe have the sony ex1, and I just found out that whenever I try to zoom in to a far subject about 100 meters, I cannot focus it. i tried doing an auto-focus, still the camera cant. Is there a problem with the lens? Can I resolve this?
Mark Levreault replied 13 years, 1 month ago 8 Members · 11 Replies -
Rafael Amador
February 21, 2010 at 7:52 amThe experts will forgive me if I say something wrong, but I think that at at full zoom no one camera can makes a perfect focus.
rafael -
Eldrin Flores
February 21, 2010 at 8:11 amWe have both ex1 and ex3, I tried a comparison with the two, focusing the same subject at a far. The ex1 seems to have problem with the lens, It didnt focus, while the ex3 focused the subject perfectly.
John Sharaf
February 21, 2010 at 3:02 pmSounds like a backfocus issue. If you can’t fix by resetting backfocus return camera to dealer or Sony for repair.
JS
Eldrin Flores
February 22, 2010 at 6:46 amthanks for the reply, Is there a backfocus adjustment for ex1?
Don Greening
February 22, 2010 at 7:28 am[eldrin flores] “Is there a backfocus adjustment for ex1?”
Absolutely. You should read this first:
https://forums.creativecow.net/readpost/142/858473
and then this:
https://forums.creativecow.net/readpost/142/862962
If the flange back adjustment doesn’t solve your issue you’ll have to send it in to Sony or one of their authorized repair facilities.
– Don
Eldrin Flores
February 22, 2010 at 7:42 amOk, I think something is wrong with lens itself. Thanks guys for the help! 🙂
Jared Meehan
September 29, 2010 at 5:23 pmCheck the external ring which holds the elements together, if this gets loose you will have this problem. It normally will have a few dots of glue around the edge but they sometimes break loose and the ring will slowly loosen letting the elements move forward and effect focus
Michael Weisman
April 10, 2012 at 7:06 pmBrilliant Jared!
I was having this exact same problem today – not being able to get a sharp focus at full zoom – and sure enough, just as Jared suggested, my front element ring was about 2 turns loose! Snugged it up and all is back to normal.
Thanks Jared! You saved me a trip to $ony $ervice!
Regards,
Michael
