  • Posted by Jonny Filsinger on March 28, 2008 at 2:40 pm
    First of all let me say that we liked our Sony EX1 so much that we just got our second. The question I have involves backing up the cards. We have some major shoots coming up where we will have to offload the cards and reuse them. I would like to go to 2 drives at the same time. What would be the most efficient and practical means of doing this. Could you have 2 Lacie drives set up with a USB splitter or is there a better way of achieving this? I will have my 17″ MacBook Pro in the field with us. I have also brought up this question in the Sony CineAlta forum. Your input is welcome and thanks in advance.
    Jonny Filsinger
    Master Video Productions, Inc.
    2832 Bartlett Rd.
    Memphis, TN 38134
    901-372-7012
    Jonny Filsinger replied 18 years, 5 months ago 6 Members · 6 Replies
  • Zak Mussig
    March 28, 2008 at 3:04 pm
    Jonny,
    All you have to do is drag the BPAV folder from the card into a folder on the drive. If you want it on two drives just copy to both drives. This will obviously increase the amount of time a card is out of commission for backup. You could also find some utility ( which automatically backs one drive up to the other as it’s modified using watch folders or some such thing.
    The transfer software won’t accept the BPAV folder on its own… it has to be wrapped in another folder (or the card’s volume). This actually helps keep track of the cards and it forces you to organize and avoids accidentally overwriting a backup from another card. Make a “card backup” folder and inside that make a new folder with a more descriptive name for each card you copy to disk, the dump the BPAV folder from the card into this folder. (e.g. card backup > 3-24 Client 01 > BPAV)
    Then just add each of the folders in card backup as sources in the transfer app.
    Zak
  • Rafael Amador
    March 28, 2008 at 4:59 pm
    Hi Jonny,
    I have two LaCie ready for the field. I haven’t used them yet, but my idea is to download for duplicated, in one disk the just dragging the files from the SxS card and in the other disk with the Transfer Software. I’ll plug the SxS cards to the MBP slot and FW800 for the disks.
    This machine from Sonnet looks better than the LaCies:
    https://www.sonnettech.com/product/fusionf2.html
    But still a bit expensive.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Arnie Schlissel
    March 28, 2008 at 9:32 pm
    [Zak Mussig] “You could also find some utility ( which automatically backs one drive up to the other as it’s modified using watch folders or some such thing. “
    Check out Carbon Copy Cloner. I used this for backing up P2 to a 2nd hard drive. Works quite well.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Jeff Coleman
    March 28, 2008 at 9:33 pm
    https://www.wiebetech.com/products/RTX200.php
    https://www.wiebetech.com/products/specsheets/RTX_200H_QR_spec.php
    RTX200H-QR by Wiebe Tech looks interesting to me. Plenty of interface choices. I thought people were using one of their RAID 1 products pretty regularly in field for Panasonic P2.
    Run it at RAID 1. Pop out the bare drive and put it on the shelf in one of their $5 boxes. You don’t have to use their drives. You might call ’em and see if they have a better reco.
    Let us know what works.
  • Jim Kinsey
    March 29, 2008 at 2:47 am
    We just got our Ex1 and the new Sonnet fusion F2 (640 GB) and raided it in the disc utility app ( comes with the instructions ). So our work around since the drive connects via the express card port (eSATA) basically it takes up the express card slot.
    1.) Copy your BPAV folder from your SXS card to your Macbook pro desktop first.
    2.) Eject your card
    3.) Insert express card/esata adapter for the fusion F2 and hook up your drive with the esata cables ( the F2 is powered by a supplied firewire 400 cable.
    4.) Copy BPAV folder from desktop to F2 raid
    5.) Erase folder from desktop
    6.) eject F2 fusion disc
    7.) insert SXS card and erase with piece of mind knowing your files are safe.
    This might seem extreme but it could potentially save you from a drive going down and for same day editing this baby is faster than any bus powered drive in its class.
    jim kinsey
  • Jonny Filsinger
    March 30, 2008 at 12:34 am
    Thanks everyone. You’ve given me some great information as usual.
    Jonny Filsinger
    2832 Bartlett Rd.
    Memphis, TN 38134
    901-372-7012
