EX1 and EX1R for shoot – advice needed re sync
I will be using an EX1 (my own) and a hired EX1R (which I have never used but assume its pretty much the same?) for a live shoot next Friday.
Now, I don’t use picture profiles very often and need to brush up a bit on how to set them up, but I assume this is the best way to ensure the pictures from both camera is identical (as well as other factors such as aperture)?
The other aspect to consider is sound. The person I am filming will be jumping around loud and then very quiet as he is a story teller. I was going to link up two mics – both SENNHEISER EVOLUTION EW112-P G2s. The test revealed that the two receivers couldn’t be too close as interference is heard, but as long as they are kept fairly far apart all is good. I will have the sensit high on one and low on the other.
Does this all sound sensible – any advice welcome.
If I am honest, I am using two camera’s not just because I want to vary the event, but because I am dreading trying to keep a tight shot on him without it jerking. At least if I use a wide shot, then I an cut between them!
Compressing to web, I can use 200% in FCP zoom which gives me a lot of room, but for DVD I would imagine I cannot get away with more then 150%?
Olly Lawer
