EX Edit to SD DVD Test Results
I posted this before, and I think it got buried in a thread and no one saw it, so I’m posting it again, ’cause I put a lot of time & effort in it, and I think it’s helpful:
I have Doug Jensen’s DVDs and I wanted to test his method for outputting SD from EX footage, so yesterday, I took some footage that I had shot with my EX while on vacation, and edited together an 8 1/2 minute piece. It had a few dissolves, a supered title, and one clip in with variable speed. The piece was shot in 1080 30p, and I edited it three different ways. The first, I edited in it’s own native format. The second one I did the same, but then copied the whole thing and pasted it into a DV-NTSC Anamorphic timeline. The third, I edited from start to finish in the DV timeline. Since I am looking for the fastest-most streamlined workflow, I did not render anything during editing. I just exported each sequence directly from FCP into Compressor, with a 1-pass CBR of 7.4.
The first method (XDCAM sequence) took 23 minutes
The second method took 15:30
The third method (Doug’s method) took 14:30This is on a MacPro 2.66 Quad
I then burned a DVD and compared. All three looked great and virtually identical. It might be that version one looked a bit sharper than the others, but it was so close that it could be my mind playing tricks. I viewed the DVD on a Sony 36″ SD monitor and also my Samsung 56″ dlp HD monitor. There was a little bit of aliasing on some of the fine horizontal lines when viewed on the Sony, but I attribute that to the fact that the TV does not support Progressive.
It looked amazing on the Samsung which I attribute to the excellent upscaling of my Blu-Ray player.Now, since it was a pretty simple edit with mostly cuts and no filters, I don’t know how different the editing process would be when working native vs. in an SD timeline. I’ll have to try a full project before I figure that one out. But, for the time being, Doug appears to be correct.
Next. I wanted to see how long it took if I rendered first before compressing, so I took the SD sequence and rendered it first, before exporting a Quicktime movie, and then taking that into Compressor. It only took 2 minutes in Compressor, but took 18 minutes to render. So, the whole process was 5.5 minutes longer than exporting directly to Compressor without rendering first.
