Activity Forums Sony Cameras EX 3 setting to PMW-350
  • EX 3 setting to PMW-350
    Posted by Robert Stagg on June 10, 2010 at 8:01 am
    I’m trying to replicate my EX 3 picture profile, preset settings on a PMW-350 and am having trouble with finding an equivalent gamma related settings in particular the cine 3 setting can anyone help! Please
    thanks
    Rob Stagg
    Thomas Vecsei replied 16 years, 2 months ago 6 Members · 6 Replies
  • Ron Pestes
    June 10, 2010 at 4:53 pm
    I’m not sure this would work but have you tried copying your profile from the EX-3 to an SxS card and then saving it to the 350?
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Don Greening
    June 10, 2010 at 6:53 pm
    [Ron Pestes] “I’m not sure this would work but have you tried copying your profile from the EX-3 to an SxS card and then saving it to the 350? “
    Yeah, that has to be a global function on all EX camcorders. Good call.
    – Don
    Don Greening
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Bruce Rawlings
    June 11, 2010 at 7:28 am
    Worth a try but remember EX1 and EX3 sufs are not compatible. You can dial in values and see what happens. Alister Chapman is probably the man to ask about this.
  • Michael Palmer
    June 11, 2010 at 2:07 pm
    “remember EX1 and EX3 sufs are not compatible”
    I can make it work, if you open the file and find the next subfolder (EX1) you can rename it (EX3) for the camera model it is going into and then it works. I don’t know if this will work for the PMW350 but it does work between the EX1 and EX3.
    Good Luck
    Michael Palmer
  • Bruce Rawlings
    June 11, 2010 at 2:32 pm
    Good to know , never seen this published before.
  • Thomas Vecsei
    June 29, 2010 at 10:30 pm
    Hi Rob,
    I think that the PMW-350 profile HG 4 4609 or HG 1 3250 nearly matches the EX3 CINE3 PP. But without adjusting the yellows (via Matrix on EX3) these are too strong on the EX3. Just take a look at my comparison of the EX1, PMW-350 (and Canon 550D/T2i) profiles:
    https://eventfilm.at/blog/?p=41
    best regards
    Thomas
    Thomas Vecsei
    info@eventfilm.at
    http://www.facebook.com/eventfilm
