Activity Forums Sony Cameras ex-3 firmware
  • Ian Cook
    September 27, 2010 at 1:16 pm
    Hi Ronnie,
    v1.10 is required for SDHC and SxS-1 cards.
    If you are at 1.10 or higher your firmware version info is available in menu–>Others. If you are below 1.10 you need to access the maintenance menu (Menu + Rotary wheel + Cancel) and look in IF (Information)–>VERSION.
    Cheers,
    Ian
