Activity › Forums › Sony Cameras › EX 1 will not power up
  • EX 1 will not power up
    Posted by David Mcguire on May 30, 2011 at 11:08 am
    Im in the field shooting an expedition in the Philippines. Its humid and hot and Ive been shooting underwater (no problems with housing) and above for a month.
    Now my EX1 will not power up. Ive been in air conditioning for the first time and its 100 degrees outside and 100% humidity. Ive tried putting it outside (in the cracked case) but no luck.
    Im back to the P2 B cam.
    Any advice?
    thank you
    David
    David McGuire
    Seastewards.org
    Media for a Healthy Ocean
    Chris Cottrell replied 13 years, 5 months ago 7 Members · 10 Replies
  • 10 Replies
  • Craig Seeman
    May 30, 2011 at 3:02 pm
    Have you tried using AC power?
    Any error or warning messages on the LCD?
  • Noah Kadner
    May 30, 2011 at 7:18 pm
    Could be fried… 🙂 I’d guess water damage. Can you get it to a service center? If not- leave it unpowered for a while and maybe it will dry out. A bowl of rice in the sun would be one way to try to dry it up.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
  • David Mcguire
    May 30, 2011 at 11:12 pm
    Hi Craig,
    Nothing when it is plugged in either. Looks like a dead circuit board.
    regards
    d
    David McGuire
    Seastewards.org
  • Craig Seeman
    May 31, 2011 at 2:17 am
    Hmm, it went quietly. Nothing from AC obviously is bad. It could be the power in went bad so that would only be a little less than the motherboard given Sony’s prices.
  • Craig Seeman
    May 31, 2011 at 2:19 am
    [Noah Kadner] “A bowl of rice in the sun would be one way to try to dry it up.”
    You think a nice dinner will work? Pilaf or Biriyani?
    I’d be concerned about leaving it in the sun though given the potential heat and humidity situation. Similarly you could leave it in room with a constant climate for couple of days also pulling the internal battery. These are all list ditch efforts though.
  • Noah Kadner
    May 31, 2011 at 9:29 pm
    Personally I’d go with brown rice as white is the bigger carb hit.
    Noah
  • Chris Cottrell
    May 31, 2011 at 11:02 pm
    The problem is moisture. The different climates def. had a hand in this debacle. Once moisture enters the boards, it starts to corrode the circuts. I have seen this in MANY of the units brought in to me for repair.
    http://www.tekmg.com
  • Steve Wargo
    June 1, 2011 at 2:57 pm
    It may work after a day or two. We had the same thing happen in Alaska with an S-VHS camcorder in ’87 and after 3 days, everything worked fine.
    Or, if it is a corrosion issue, things will only get worse.
    Maybe it needed to be in one of those underwater bags ????
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
    Ask me how to Market Yourself using Send Out Cards
  • David Sadler
    April 8, 2013 at 9:25 pm
    My Ex-1 powers up but at times stops recording. I might go through both cards but on and off. Am told it is the mother board at fault.
  • Chris Cottrell
    April 9, 2013 at 2:56 pm
    David, What version firmware is your EX?
    http://WWW.TEKMG.COM
