Activity Forums Sony Cameras EX-1 settings help
  • EX-1 settings help
    Posted by Craig Maynard on September 15, 2008 at 3:46 pm
    Hi All,
    I am using an EX-1 shooting a high school football game from the top of the stands using HQ1080/60i.
    I then imported clips with XD Transfer to an import folder. After that I imported to FCP 6.04 using Sequence Preset XDCAM EX 1080i60 VBR and Capture Preset HDV. I then sent to Compressor and used the DVD Best Quality 120 minutes setting for both the video and audio. The video looks great when looking at the clips but after I burned it to DVD it doesn’t look that great there is a lot of screening and just not sharp even viewed on a HD TV. Are my settings wrong or is there something else I should be doing? Any help would be greatly appreciated.
    Sincerely,
    Craig Maynard
    Chris Babbitt replied 17 years, 11 months ago 3 Members · 4 Replies
  • Olof Ekbergh
    September 15, 2008 at 4:03 pm
    You are burning a SD DVD not HD and the footage has been compressed a lot.
    Even seen on a HD TV it is still SD.
    You can make a HD-DVD compatible Disc from a standard DVD-R, if you have a HDdvd player but 20 minutes is about all you can put on it. This looks very good.
    Or you could make a Bluray disc if you have a Bluray burner and Toast with HD plugin, then you need a Bluray set top player. This also looks very good.
    You can also make a better SD-DVD with better compression using Bitvice™, but it will not look like HD because it is SD.
    Olof Ekbergh
  • Olof Ekbergh
    September 15, 2008 at 4:04 pm
    Olof Ekbergh
  • Craig Maynard
    September 15, 2008 at 4:21 pm
    Thanks for the response!
    Most if not all of the people that will be getting the DVDs of the games don’t have Blu-ray. Would it be better to shoot at a lower res and use less compression? What would look the best considering the SD limitations? I don’t mind not distributing in HD, but I need to get the quality a little better.
    Craig Maynard
  • Chris Babbitt
    September 15, 2008 at 6:57 pm
    Have you looked at it on an SD monitor? In my experience, even standard-def broadcast or cable TV looks lousy on an HD monitor. The best way to evaluate SD video is on a SD monitor.
