Activity Forums Adobe After Effects Expressions Evolution Time Expression Cap!
  • Evolution Time Expression Cap!
    Posted by Oliver Main on November 8, 2019 at 3:20 am
    I’ve created an adjustment layer to give my comp a hand drawn look.
    Using TurbulentDisplace with a time expression on the evolutions, looks like this.
    posterizeTime(6)
    time*1500
    After 91 evolutions (about 20 seconds) it stops working. My comp is 60 second and I can’t spilt it up.
    Is there a way around this cap?
    Thanks for your help in advance!
    posterizeTime(6)
    time*1500
    Oleg Pirogov replied 6 years, 10 months ago 2 Members · 1 Reply
  • Oleg Pirogov
    November 8, 2019 at 12:17 pm
    It breaks at 91 rotations + 8 degrees i.e. at 32768. After that value it skips visually to -32768 and stays there, while the counter goes on. Apparently, this limitation is due to the maximum value of short integer type variable: 32767.
    A workaround would be to make a smooth loop for evolution within the boundaries of [-32768, 32768].
    Not sure, how smooth it will be in your project, but for starters you can try:
    posterizeTime(6)
    time*1500 % 32768
