Activity Forums Apple OS X Everything Crashes — Snow Leopard
  • Everything Crashes — Snow Leopard
    Posted by Nick Pope on March 11, 2010 at 12:31 am
    I don’t know if this is an application issue or an OS issue, so I’ll start here.
    All day today I have been getting Panic Crashes. 7 so far from After Effects (3 from attempted RAM previews, 4 from attempted renders).
    I’ve also received several straight crashes from Final Cut Pro (3 in total).
    Here’s my specs:
    2 x 2.93 GHz Quad-Core Intel Xeon
    16 GB 1066 MHz DDR3
    Mac OS X v10.6.2
    16GB Memory
    Running a 700GB Hard drive with a 1.5TB Spare HD for projects.
    Media is stored onto Rorke connected via MetaSAN using 1GB Fibre.
    Capture Scratch is to MetaSAN Volume A (24TB) and Render Scratch to Spare HD.
    After Effects CS4 with complete Boris Suite, Magic Bullet Suite, Trapcode Suite, & Zaxwerks Suite.
    Crashes occurring today on projects combining Boris, Trapcode and Magic Bullet. Have had image buffering issues on projects with Zaxwerks and plain ol’ solids. Also crashes on rendering a project created in CS2 and updated in CS4.
    Final Cut Pro (7.0.1) utilizing footage in Apple Pro Res NTSC 29.97 SD. Pull direct from MetaSAN.
    I also occasionally get a failure to launch PhotoShop due to lack of memory.
    So….what the F is going on? I have plenty of memory and the latest versions of damn near everything.
    Any help would be appreciated.
    Pasi Koivisto replied 16 years, 5 months ago 2 Members · 1 Reply
  • Pasi Koivisto
    March 11, 2010 at 7:24 pm
    Did you upgrade the ram recently? To me it sounds like bad ram. I would put in the install DVD that came with the computer and hold down D when you boot it, run the extended tests. There’s also an application called rember which you could use to test.
    /Pasi
    Editor, Colorist.
    Mac Pro, 8×3 Ghz, 8 Gb ram, ATI Radeon HD 4870, KONA 3, Sony PVM20L4, Tangent Devices Wave.
