Activity Forums Adobe After Effects Expressions Every X seconds, move in a random direcition.
  • Every X seconds, move in a random direcition.
    Posted by Dan Thompson on September 27, 2020 at 9:00 pm
    I’m looking for an expression that will move my layer a certain amount in a random direction every few seconds.
    The key here is that the layer needs to stay still between each movement, for a duration of my choosing.
    I’ve looked online and only found similar expressions, however my AE skills are pretty much zero so I wasn’t unable to edit them to my desired results even after a couple of hours of trying.
    Thanks a lot!
    Dan Thompson replied 5 years, 11 months ago 3 Members · 5 Replies
  • Scott Mcgee
    September 28, 2020 at 8:00 am
    This will help you get started
    segDur = 1;
    minVal = [0.1*thisComp.width, 0.1*thisComp.height];
    maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
    seed = Math.floor(time/segDur);
    segStart = seed*segDur;
    seedRandom(seed,true);
    startVal = random(minVal,maxVal);
    seedRandom(seed+1,true);
    endVal = random(minVal,maxVal);
    ease(time,segStart,segStart + segDur, startVal, endVal);
    This was by Dan Ebberts from his website here https://motionscript.com/mastering-expressions/random-1.html
    As for the pause in the middle. I don’t have time to write some up, but you should be able to add a delay between each movement.
    Hope this steers you in the right direction.
  • Dan Thompson
    September 28, 2020 at 12:44 pm
    Thanks! I’ve already found this guy’s expression for random movement, but like you said it doesn’t have the pauses.
    I’ve tried for hours to add pauses but I’m failing to even get a clue on the very basics.
    If anyone can still help that’ll be great 🙂
  • Dan Ebberts
    September 28, 2020 at 2:14 pm
    Something like this maybe:
    moveDur = .5;
    holdDur = 2;
    segDur = moveDur+holdDur;
    ease(time,segStart,segStart + moveDur, startVal, endVal);
  • Dan Thompson
    September 28, 2020 at 3:00 pm
    That’s great! Thank you so much!
    The only question I have now is which parameter can I edit in order to increase the minimum travel distance?
    EDIT: Adding a multiplier to startVal and endVal seems to help, but it sometimes creates a “jump” right before the layer starts moving.
    **Another note, I don’t need any “protection” that prevents the layer from flying out of the canvas, if that matters!
    Thanks again!
  • Dan Thompson
    September 30, 2020 at 2:17 pm
    Alright I got what I wanted and fixed the problem by adding a multiplier to the minVal and maxVal instead!
    Thanks again 😀
