Activity Forums Adobe Premiere Pro Every possible metadata DATE column is wrong
  • Every possible metadata DATE column is wrong
    Posted by Alex Ezorsky on November 16, 2018 at 4:36 pm
    And yet right there in windows explorer it’s correct. Why can’t Premiere read that? What’s with it thinking it’s 1903?
    John Pale replied 7 years, 9 months ago 3 Members · 2 Replies
  • Greg Janza
    November 17, 2018 at 6:09 pm
    we’ll need more info than what you’ve provided. What version of Premiere are you working with? What are your system specs? Have you opened the metadata panel and looked to see what info is listed? Does the metadata panel info match the bin listings? What camera is the media coming from?
    Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
    Adobe CC 2019 13.0 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
  • John Pale
    November 17, 2018 at 7:28 pm
    That Date/Time Digitized column is additional metadata that is burned into the file, but is not normally able to be seen in Windows Explorer or Finder on a Mac. It’s part of EXIF data generated by the camera. Premiere (and Photoshop) read this data and rely on it more than Windows or MacOS. I’d look at the camera that created the files and adjust the date/time on it.
    If you want to see for yourself, right click on the top bar and select “Metadata Display”. Do a search in the search field for Date Time Digitized. You will see that metadata is in the EXIF Schema for EXIF Specific Properties. This is not part of the standard set of metadata that you see displayed in Premiere or Windows Explorer/Finder.
