Activity Forums Creative Community Conversations Events and Projects Librarys Missing in FCPX (but folders and videos in finder exist)
  • Events and Projects Librarys Missing in FCPX (but folders and videos in finder exist)
    Posted by John Smith on December 22, 2011 at 8:53 am
    I am now seriously annoyed at this.
    All of my Events and Project Librarys are missing when I load up Final Cut Pro X. As its loading the splash screen it spins through that its reading the event library, restoring windows etc etc
    But when its fully loaded up there are NO Events or Projects listed.
    Can anyone advise what to do here?
    Previous to this I had a solution where I kept rebooting the computer until they finally all showed up in FCPX again, but this has now completely stopped working.
    All of my files still exist correctly, but its just like FCPX doesn’t see them (they are all sitting on my internal HD)
    I have files called
    CurrentVersion.fcpevent
    sitting in
    Movies>Final Cut Events>(Name of Event)
    and files called
    CurrentVersion.fcpproject
    Sitting in
    Movies>Final Cut Projects> (Name of project)
    All of my video media exists in
    Movies>Final Cut Events>Name of Project>
    Original Media
    in their individual folders
    If I double click from Finder and try to open a
    I get the pop up
    The document “CurrentVersion.fcpevent” could not be opened.
    I get the pop up
    The document “CurrentVersion.fcpproject” could not be opened.
    Everytime I start up FCPX it creates a
    NEW EVENT (plus the date)
    in my Final Cut Events folder.
    So, any help anyone?
    I’m now thinking what a terrible choice it was to ever bother buying and spending weeks learning how to use FCPX properly and that I should have used a different video editing program instead.
    This is seriously depressing 🙁
    Ted Hogeman replied 13 years, 8 months ago 9 Members · 58 Replies
  • 58 Replies
  • Nick Toth
    December 22, 2011 at 3:33 pm
    Need more info on your setup. If you had a “solution” where re-booting several times caused the missing files to show up it sounds more like a hard drive issue. Have you run disk first aid, repaired permissions, deleted preferences etc.? Based on my experience with FCP X what you are describing sounds like something other than an FCP problem.
    NT
  • Eugeny Korkhin
    December 22, 2011 at 4:15 pm
    FCPX may treat your hard drive as a card from a camera if you have “camera related” folders (i.e. DCIM) on your drive. Check this thread for more info:
    https://discussions.apple.com/thread/3279953?start=0&tstart=0
  • Mitch Ives
    December 22, 2011 at 4:32 pm
    [Eugeny Korkhin] “FCPX may treat your hard drive as a card from a camera if you have “camera related” folders (i.e. DCIM) on your drive. Check this thread for more info:
    Thanks for the link… this is important info. So basically you can never have any files with the words “movie”, “video” or “Final” in them? All I can say is how did this get by the final testers?
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
    “Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things.” – Winston Churchill
  • John Smith
    December 22, 2011 at 4:52 pm
    I have 1864 files with the word FINAL in it according to Finder.
    There is no way I can change all of these to NOT have the word FINAL in them.
    Although I DID create a wav, aif and mp3 with the word final in it recently, but Ive already used this wav in a FCPX movie and it worked ok.
    Ive tried changing the names of SOME of the most recent files to not have the word FINAL in them, but FCPX still doesnt show up any events or projects (even thought they DO exist in their folders).
    MOVIE – Dont even go there 🙂
    VIDEO – Again, dont even go there 🙂
    I DID have an SD card connected to the Mac with a DCIM folder containing images, which I ejected. I also searched the system for DCIM and found nothing.
    but it still doesnt show up any events or projects (even thought they DO exist in their folders).
    Ive been going through Disk Utility, Verifying and Repairing Disk Permissions.
    REPAIR DISK is always greyed out though.
    Still nothing.
  • John Smith
    December 22, 2011 at 5:23 pm
    Ive also just booted up with the OSX disc and REPAIRED then system.
    But its still not showing up events and librarys
  • Eugeny Korkhin
    December 22, 2011 at 5:26 pm
    I never had this problem by myself, so I can only guess. But it seems to me that it relates to folder names, not files. And not only DCIM folder may cause trouble, but other camera-specific names as well.
    That is a bug. No doubt. But Apple can call it a feature:)
  • John Smith
    December 22, 2011 at 6:03 pm
    More updating.
    I tried the hide/move events/projects files into new folder
    as explained here
    https://support.apple.com/kb/HT4740
    and it STILL doesnt work.
    I even tried it with individual events projects, but nothing 🙁
  • Jeremy Garchow
    December 22, 2011 at 7:35 pm
    Have you tried moving the events/project to an external drive?
  • Bill Davis
    December 23, 2011 at 2:40 am
    If I read all the threads correctly, it seems this isn’t actually a Final Cut Pro issue so much as an underliing Unix file tree issue.
    It starts with the poor practice of doing FINDER copies of card data that creates essentially false directory tree branches that X “thinks” leads to cards – but don’t.
    How can the program tell whether a particular DCIM file is a proper camera clip or a finder tag for an asset collection? My brain can supply context based on where amongst the thousands of possibilities I put it – but I don’t think the computer’s directory is going to parse that.
    I”m also suspect since thee original posts about this were from September, and if this was persistent and universal, I think we would have seen a LOT more squawking about this – since tagging a clip as a FINAL has got to be a pretty universal convention and I’ve done it quite a bit myself without any hassles.
    Bottom line. Archives and/or Disk Images are your friend, since it appears that FCP-X never gets confused no matter how many of them are on a hard drive and how many you open to re-populate your projects. They just work and simultaneously keep all the directory structure info in precisely the same state it was when the card came out of the camera.
    FWIW.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • John Smith
    December 23, 2011 at 9:57 am
    Hi Bill
    Thanks for your comments but I am still looking for a solution to this problem. Even if this is an issue with my system and not with Final Cut Pro.
    Out of EVERY app I have this is the only app that I am experiencing any problems with. This is why I am calling it a FCPX fault.
Page 1 of 6
