Event Pan/Crop Problem
Posted by Joao Souza on March 12, 2015 at 3:34 pmIf I try to make an event pan/crop zoom in three channels simultaneously, Vegas crashes no matter what type of file I try to render.
No, I won’t group them and use their grouped parent motion to zoom cause event pan/crop zoom quality is way better.
What could be causing this?
Is it a known problem?
Thanks 😉We have so much time and so little to do! / Willy Wonka
Joao Souza replied 11 years, 5 months ago 4 Members · 11 Replies -
Graham Bernard
March 12, 2015 at 5:48 pmSupply a ScreenGrab, might help us?
To assist you in answering your question:
1] What is the media?
2] What are your project settings?
3] What are you encoding to?
4] Do you have GPU acceleration ON?
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Joao Souza
March 12, 2015 at 5:59 pmNone of these matter cause it only happens while event pan/crop zooming 3 channels
It’s an specific problem which have nothing to do with my settings which are the same as everybody use here and around the net, nothing different or special.
I guess you never saw that problem so you can’t help me.
Thanks Graham.We have so much time and so little to do! / Willy Wonka
Graham Bernard
March 12, 2015 at 6:38 pmI agree.
G
Mike Kujbida
March 12, 2015 at 6:59 pmJoao, what version of Vegas are you using? I just tried a 4 channel zoom out using Pan/Crop on stills and everything worked as expected.
edit: this was using Pro 12 -
Joao Souza
March 12, 2015 at 7:38 pm[Mike Kujbida] “Joao, what version of Vegas are you using? I just tried a 4 channel zoom out using Pan/Crop on stills and everything worked as expected.
edit: this was using Pro 12”Hey Mike Vegas 11.0.
Did you render it?
My problem is about rendering it.We have so much time and so little to do! / Willy Wonka
Mike Kujbida
March 12, 2015 at 7:45 pmSorry but I went right from Pro 10 to Pro 12.
Are you using the latest build? A browse of the release notes shows a few issues with the Pan/Crop tool that were fixed at various times. The most recent one was in build 700/701.Notable fixes/changes in version 11.0 (Build 700/701)
Fixed a hang that could occur when rendering when a pan/crop rectangle is moved completely off an image.
Joao Souza
March 12, 2015 at 7:51 pm[Mike Kujbida] “Sorry but I went right from Pro 10 to Pro 12.
Fixed a hang that could occur when rendering when a pan/crop rectangle is moved completely off an image.”
Mine is build 700.
I google’d but found nothing about that zooming problem.
If everybody with Vegas 11 had that problem so I’d consider moving to 13.
My puter is 32bit so I won’t change vegas and windows because of a zoom problem LOLWe have so much time and so little to do! / Willy Wonka
Mike Kujbida
March 12, 2015 at 7:54 pmVery strange. The only thing I can suggest is to post your veg file and let us try to see if we can replicate your problem.
Joao Souza
March 12, 2015 at 8:14 pm[Mike Kujbida] “Very strange. The only thing I can suggest is to post your veg file and let us try to see if we can replicate your problem.”
How could I do that?
Steve Rhoden
March 13, 2015 at 11:14 amVery strange, not sure what could be your problem. However
i use Vegas 13 and tried what you are doing several times with
no rendering issues at all.
Could possibly been a bug in Vegas 11 that nobody hardly noticed!Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia
