Event Pan And Crop
Posted by Sawyer Porter on September 20, 2013 at 11:09 amIm trying to do a side by side of to videos ive taken but its not letting me put it to the edge of the screen im in 1280 x 720 and the videos when there close to the edge they start dispersing please help
John Rofrano replied 12 years, 11 months ago 5 Members · 5 Replies -
John Rofrano
September 20, 2013 at 3:36 pm[sawyer porter] “Im trying to do a side by side of to videos ive taken but its not letting me put it to the edge of the screen im in 1280 x 720 and the videos when there close to the edge they start dispersing please help”
It sounds like you might not be matching the aspect ratio of your events correctly. Try my tutorial:
Creating a Split Screen using a Mask
and see if it helps.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Andrew Lenczycki
September 20, 2013 at 3:55 pmYou would do this using Track Motion on the header for each video track:
Put Video1 on Track 1, Video2 on Track 2, directly on top of each other.
Press the Track Motion button on the Track 1 header to open the Track Motion window. Set the Position|Width and Position|Height to 1/2 the current dimensions (which should be 1280 x 640) or 640 & 320. This will make Video1 “half size” to fit onto your 1280 x 720 screen. You also need to adjust the Position|X from 0 to -320 (which moves Video1 over to the left side of the screen).
Set the exact same things in Track Motion for the Video2 on Track 2, EXCEPT set the Position|X to 320 (not -320). This will move the Video2 over to the right side of the screen.
If you’ve done everything right, you should see the following:
Hope this helps.
Andrew Lenczycki
Steve Rhoden
September 21, 2013 at 12:11 pmUse your Track Motion as instructed…
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
John Rofrano
September 23, 2013 at 10:59 am
