Activity Forums Live Events & Streaming Event live streaming with MacBookPro
  • Event live streaming with MacBookPro
    Posted by Matt Ray on October 12, 2018 at 10:00 am
    Hi there, i’m new to the forum and I’ve had a look around and couldn’t find the ideal place for this so apologies if there is somewhere better for this to go and please say.
    On to what I’m needing advice on as I’m a novice. I work in live events and am looking to finally do some live streaming on top of the graphics, lighting and sound. At present I’m trying to do this with about £400 budget and the main use is to live stream one camera along with a feed of content from a projector and send to other sites.
    I’m thinking of buying Blackmagic intensity extreme usb, Blackmagic ultra studio mini recorder and downloading OBS. For the audio I’d purchase a focusrite scarlett.
    What I have is an analogue mixer, MacBook Pro, 2k switcher/scaler with dvi output, hdmi HD camera.
    I plan on using an hdmi camera into the Blackmagic ultra via thunderbolt into the Mac. Using the intensity to take the content feed from our switcher/scaler (1080p DVI- can only be P signal due to projector limitations) into usb on the Mac. Audio will be an xlr out from the mixer into the Scarlett and usb out into the Mac.
    This would likely be streamed to our business intranet or using YouTube channel but that’s dependent on our IT department.
    My first question is can the MacBookPro handle all these inputs easily? In future Potentially add another camera using the other thunderbolt connection.
    Will these add a lot of latency?
    Am I likely to experience audio/video sync issues? Do streaming software have these built in or would I need something front end?
    Big concern is the signal conversion from the switcher to Mac – will the BM ultra studio do the job?
    What other kit would you recommend?
    What do I need to be aware of once the signal leaves my Mac?
    If you’ve made it this far I thank you for taking the time to help.
    Cheers
    Matt
    Matt Ray replied 7 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
