Activity Forums VEGAS Pro Event flipping not working
  • Event flipping not working
    Posted by Heather Walters on December 18, 2009 at 10:15 pm
    Hey, anyone encounter this? I’m trying to flip some text vertically (for a reflection) and when I went into pan/crop and chose “flip vertically” I got no change. I tried it with an image, nothing. I tried exiting the program and restarting it. No change. Is there some secret preference that will prohibit images and text from flipping?
    Joe Mantaratz replied 16 years, 9 months ago 2 Members · 3 Replies
  • Joe Mantaratz
    December 20, 2009 at 1:48 am
    No there is no secret here for what you are doing. If you want to make a mirror image that is more realistic then I would use the track motion and not pan/crop. You will need to make two tracks with the text. Select track motion and then change the source from source Alpha to 3D and position it where you need to in relation to the other track. You will have much better control in all planes.
    Just tried to duplicate what you were experiencing and I couldn’t. Mine works just fine but I will say at times I have come across an FX, track motion, pan crop function that ceased to function for some reason. Especially seems to happen on a particular track and not all tracks. Don’t ask why I have no idea. So after racking my brains the first few times I just create a new track and then copy the track into the new one. Voila it fixes itself!! It seems Vegas gets locked in an wont let go, again don’t know why it just does.
    Hope this helps in the short turn, otherwise there is not secret anything in your case.
    John
  • Heather Walters
    December 20, 2009 at 2:01 am
    Ah, track motion, never even thought of it! Well, I was able to get it working finally with pan/crop. Problem was that if you change ‘stretch to fit screen’ in pan/crop to “no”, it keeps it flipped right side up. If you change it to “yes”, it works, but then you cannot pan or crop (which was crucial in my design)! Next time I’ll do track motion instead. Thank you!
  • Joe Mantaratz
    December 20, 2009 at 2:19 am
    Guess you found the secret….great!! Thanks for letting me know.
    Joe
