Activity Forums VEGAS Pro event duration
  • event duration
    Posted by Scott on May 10, 2005 at 3:06 am
    Hi all,
    this is probably a newbie question.
    Is there a similar way to change the duration of an event that is on the timeline?
    thanks, scott
    Timothy Duncan replied 21 years, 3 months ago 3 Members · 2 Replies
  • Gary Kleiner
    May 10, 2005 at 3:22 am
    [scott] “Is there a similar way to change the duration of an event that is on the timeline? “
    Similar to what?
    Gary Kleiner
    Vegas Training and Tools.com
  • Timothy Duncan
    May 10, 2005 at 2:29 pm
    Go under “view” and select “edit details.”
    Stretch this window out across your screen. Re-arrange your Vegas layout so that this window is always visible somewhere, either across the top, or bottom of the main Vegas timeline.
    Select any clips — have at tons of controls including duration, timeline in/out and clip in/out based on TC. You also get all the switches such as loop, lock, mute, normalize, etc.
    This view is one of the best kept secrets in Vegas.
    td
