Activity Forums VEGAS Pro Event Attributes
  • Event Attributes
    Posted by Gdaronne on November 25, 2006 at 4:10 am
    I’m color correcting video and once I get the correction I need, I copy to other clips with similar color problems. The problem that I’m having is that when I correct the event and replay it the color changes as if it’s keyframed. For instance, let’s say the video is too red and I apply color correction to it and it now has the right skin tone. When I play it back, it goes from red to the correct skin tone instead of as if it’s keyframed. I know there a simple solution but I can’t figure it out. I’d appreciate any feedback.
    Gdawgs
    Richard Klimesh replied 19 years, 9 months ago 5 Members · 5 Replies
  • Gdaronne
    November 25, 2006 at 4:25 am
    I figured it out. I need to select the entire event. I knew once I posted this message I would come up with an answer.
    Gdawgs
  • Peter Wright
    November 25, 2006 at 8:52 am
    Yes it’s easy to forget that the Synch Cursor button has been left activated.
    When I remember, which is most of the time, I always turn it off again once I’ve finished doing a deliberately keyframed sequence, so that I don’t set up an inadvertent keyframe as you seem to have done!
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Chris Young
    November 26, 2006 at 10:30 am
    Geez! Whish I had a $ for everytime I’ve done that in the past. Do the same now, turn off sync cursor everytime when finished with a keyframe sequence.
    Chris Young
    CYV Productions
    Sydney
  • Graham Bernard
    November 27, 2006 at 9:17 am
    Yeah .. me too . .And also when I pick a CC FX to start with, I NOW make sure I haven’t picked one that has ALREADY been altered! Oh yes, I’ve banjaxed myself with THAT one too! And not on one occasion either!
  • Richard Klimesh
    November 29, 2006 at 1:48 am
    …banjaxed? Isn’t that something that happened to The Bush Mechanics?
    klimvid
