Activity Forums Apple Final Cut Pro Event and Project sharing variant?
  • Event and Project sharing variant?
    Posted by James Culbertson on March 21, 2013 at 5:38 pm
    If I ingest a camera archive and a collaborator ingests a camera archive, would the resulting event folders be considered to be mirrored such that project sharing would work properly?
    I did a quick test here with two separate drives (and a couple of DSLR clips) that worked. But I wonder if it works more universally.
    James Cude replied 13 years, 5 months ago 2 Members · 1 Reply
  • James Cude
    March 21, 2013 at 9:53 pm
    Can you be more specific? Generally speaking if you and a colleague ingest the identical media and don’t alter it you should be able to link projects that way. Ideally though you would share the same media and one person ingests and then sends an Event to make it perfect.
