Activity › Forums › Adobe Illustrator › Evenly thick stroke
  • Evenly thick stroke
    Posted by Thomas Cramer on April 4, 2019 at 8:00 am
    Hi
    Im trying to replicate the black graph behind the red with a stroke. Unfortunately the stroke gets very thick at the top and bottom of the graph peaks. Any suggestions how to replicate this, so that other button elements can have the same look?
    Thanks for your input!
    Kalleheikki Kannisto replied 7 years, 5 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    April 5, 2019 at 2:13 pm
    Use curvature (the corner rounding gizmo) at the corner points to round them some.
    Senior Graphic Designer
  • Thomas Cramer
    April 10, 2019 at 10:51 am
    Thanks a lot for helping, but I’m not sure that the curvature tool will help me get the result I was hoping for.
    I have attached another image indicating the stroke with red. The original artwork is below with black. I guess the original artwork was created with a stroke initially and then being outlined to achieve the same width all along the path.
    The issue seems to be where the joins are. They are rounded on the outer part of the joins and sharp on the inner. But I can’t get the inner part to have the same width as the straight line segments.
    Hope for more good advice ☺
    April 11, 2019 at 8:18 am
