Activity Forums Maxon Cinema 4D Even out lighting in floor reflection.
  • Even out lighting in floor reflection.
    Posted by Tom Slinger on January 28, 2023 at 6:53 pm
    Hi guys,
    I’m almost happy with the render here, the lighting on the contact lens is good.
    The reflection needs work. The reflection needs to be a solid white instead of this dark gradient bottom left.
    The thing is, when I try to address the gradient in the reflection the lighting in the contact lens changes too much and looks different to what I need.
    I guess I need a light or similar which doesn’t affect anything apart from the floor to even up the lighting in the floor reflection.
    I’ll also add a falloff to the contact lens reflection too.
    Any tips on this or generally improving the shot would be greatly appreciated.
    Tom
    Usama Aslam replied 3 years, 7 months ago 2 Members · 1 Reply
  • Usama Aslam
    February 10, 2023 at 9:26 pm
    Even out the lighting in floor reflection.
    Have you tried using a different render engine like Corona renderer, Octane render, Anorld, or Keyshot?
    If not, then it will definitely help you out a lot with your results.
