Activity Forums Maxon Cinema 4D Even Cuts
  • Even Cuts
    Posted by Bryan Richards on February 6, 2007 at 6:10 pm
    While im in Polygon mode, i have selected one polygon that sits on the side of an editable object. I need to split this panel up in to x number of even panels. The knife tool allows me to make 1 cut, however id like to make multiple cuts which are evenly spread out over a the distance of the polygon preferably with a parameter of “number of cuts”..
    Is this possible?
    If not is there a another automatic way of dividing up a polygon which gives me independant control over the new polygons created.
    Cheers
    BMR
    Adam Trachtenberg replied 19 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 6, 2007 at 8:25 pm
    Yes, it’s possible with the “Edge Cut” tool. 🙂 Just select the edges and you can get an interactive preview of the cuts. Hint: turn off the default “ngons” option.
