Activity Forums Boris FX Particle Illusion Evaluating PI SE demo, getting distorted background image…?
  • Evaluating PI SE demo, getting distorted background image…?
    Posted by J0hnnyg on April 27, 2007 at 8:39 pm
    When adding avi converted from mpeg2 using BlazeMedia Pro, image is very distoreted and shows 4 of the same image across the background. Same result at 29.97 or 30 FPS. PC is AMD XP 3200+ with ATI all-in-woner x600 or x800 (posting from work, not sure). Works fine on my laptop though…? Any thoughts on how to fix? I want to install the purchased version on my tower v/s my laptop.
    Elvis Deane replied 19 years, 4 months ago 2 Members · 3 Replies
  • Elvis Deane
    April 28, 2007 at 3:44 am
    What codec did you use to compress the AVI? I’ve seen some funny things with some codecs. Could also be a video driver issue. Is your laptop card also ATI, are you running the same drivers on both?
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • J0hnnyg
    May 3, 2007 at 7:45 pm
    Sorry for the late reply back and thanks for helping. I actually left the AVI uncompressed, as I was not sure which to use and the video lenght was only a few minutes. The laptop card is on-board, so it is not an ATI and would have different drivers.
  • Elvis Deane
    May 5, 2007 at 4:50 pm
    I’d first suggest getting the latest certified drivers from the ATI site to rule out any video card conflicts. BlazeMediaPro is supposed to allow you to create a sequence of images from a video clip, so you may want to try converting the mpeg into a sequence of PNG or JPGs to see if that works.
    Elvis Deane!
