Activity Forums Adobe After Effects Expressions Eval(‘@JSXBIN…’); no longer working?
  • Eval(‘@JSXBIN…’); no longer working?
    Posted by Sam Catt on October 17, 2018 at 8:37 pm
    So after updating to After Effects 2019, I’ve run into a little issue without a true way to solve it of yet. I used to be able to run expressions as jsxbin files to try and somewhat “protect” them. However, since the latest update, it no longer works. I’m guessing this is because of the new javascript engine? has anyone got a way of getting this to work? or is it simply no longer possible
    Vasyl Iskovych replied 6 years, 5 months ago 4 Members · 3 Replies
  • Dirk De jong
    October 17, 2018 at 9:39 pm
    I don’t have an answer but am also curious to know any info on this – earlier today I was seeing some scripting failures (unique to the new AE update) which I haven’t yet had time to investigate – but that would explain it (they use JSXBINs that way)
  • Azedine Hiri
    October 18, 2018 at 3:45 pm
    while i’m working on an update for my walker tool script, i did accidentally found a way to switch to the old expression engine ????
    the image shows how.
    https://imgur.com/a/7iOtoAn
    View post on imgur.com
  • Vasyl Iskovych
    April 13, 2020 at 5:28 pm
    Thank you very much.
    You helped me a lot.
