Activity › Forums › Adobe After Effects › Eurovision 2009 Effect
Posted by Andrej Spilevoj on June 2, 2009 at 10:05 amHi Guys,
Ho about a wonderful Eurovision effect when the town appears like a kids book? Could you have a look at the youtube posts to see it again, I was wondering if that is possible and how?
Michael Szalapski replied 17 years, 3 months ago 3 Members · 6 Replies -
Roland R. kahlenberg
June 2, 2009 at 2:52 pmHi there, please keep in mind that the COW has a worldwide audience -not everyone knows what you’re talking about if you refer to anything that dones’t necessarily have a global audience. And you can help yourself better by posting a link to any video or image that gives others an idea as to what you’re looking for.
Cheers
RoRKbroadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
Adobe After Effects Training in South East Asia.
Andrej Spilevoj
June 2, 2009 at 2:59 pmThis is an example from the Eurovision 2009, before each song there was a short presentation with the flipping book: https://www.youtube.com/watch?v=WbocLxXkmHQ
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
June 2, 2009 at 3:22 pmGood Job on the link! 🙂
Now, what was the question again?
Just kidding! OK, it’s a complex efffect but it’s not that difficult.
You’ll need to know how to flip a layer (page) and kowing how to place your Anchor Point is crucial.
Making the objects pop up is easy with the y-scale property.
Add some camera movements and/or use a null and use it as a parent to the other layers and animate the null to get different perspectives.
Take note that the video sample you showed uses 3D objects and very likely a 3D software to put everything together. With AE, you won’t have the luxury of moving the camera too much without giving away the fact that you are using 2.5D images.
HTH
Michael Szalapski
June 2, 2009 at 3:50 pmRoland is correct. This is a rather easy effect to emulate since AE’s 3d is essentially flat planes in space – it just takes some time, work and planning to make it look good.
Yes; they used a 3d application to do that piece – you couldn’t get something identical to theirs without some actual 3d software. However, like Roland said, you can get a look similar enough to it. It’s just a lot of well planned camera movement and carefully placed elements.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Andrej Spilevoj
June 3, 2009 at 1:28 pmThere is no problem with the 3d objects, I am on Cinema 4D too. The question is how to fold it so as it is on the video? I know it is hard to explain in words, video tutorial would be of more help. Thanks, anyway, guys.
Michael Szalapski
June 3, 2009 at 2:06 pmIf you want to make a video unfold in After Effects you are a little limited on what you can do, but you can still make it work. It depends on how complex you want to make it.
In AE there are normally several ways to achieve the same goal. I would thing the simplest solution would be to duplicate the layer you want to fold. Mask the bottom half of one copy and the top half of the other copy. Move the anchor points for each layer to the edge of the mask so the anchor points are practically touching. The keyframe x rotation. That gets you a basic fold.
Then comes the spicing it up. Put a null layer at the bottom of the image. Parent both pieces to the null and keyframe the null’s x rotation. That way it flips up as it unfolds.
This should put you on the right road to unfolding things in AE. You can make it much more complicated by having more than two pieces and the use of some clever parenting.Or you can do it in Cinema4d.
– The Great Szalam
