Activity › Forums › Apple Final Cut Pro Legacy › “European format” Delivering sequence to a user in Italy
Christopher Martin replied 15 years, 9 months ago 9 Members · 19 Replies
Christopher Martin
November 18, 2010 at 5:38 pmDoes PAL make a difference – presuming this is being played in a digital format?? ie. Assuming they aren’t outputting to tape??
Brad Elliott
November 18, 2010 at 5:40 pmWe have had success sending H264 files at best quality/multi-pass.
It is not ideal but if they have QT(Mac or PC) we have never had an experience where someone couldn’t open it. They may have to convert it to whatever they need.
Christopher Martin
November 18, 2010 at 5:42 pmI’m going to try that since it seems that h264 is a pretty widely used codec…
Jason Porthouse
November 18, 2010 at 6:00 pmThere’s nothing wrong with the file you’re sending them, the fact that they can hear audio but only see black indicates to me that they don’t have FCP or aren’t up to speed on Pro Res.
I’ve successfully used H264 for this kind of thing before, use the same specs as you have (rate, size, dominance) and make it high quality. They be able to play it, and can then encode to whatever they need should they need to edit it.
But I feel your pain – dontcha just love producers whose sum knowledge is less than b****r all who get all ansty because they think *you’re* the awkward one for asking so many damn questions?
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Christopher Martin
November 18, 2010 at 6:34 pmI used standard Youtube specs. h264, 30fps, Hi def ratios etc. Do you think this will goof them up?
Christopher Martin
November 18, 2010 at 8:02 pmDave (et al) — you’re kind to help me out…. It’s much appreciated
Great community
Aristides Tiropolis
November 19, 2010 at 1:57 pmIf they’re using the latest version of quicktime,be that Windows or Mac OSX the ProRes video should be playable, whatever the frame rate. If they see black they could have problems in their computer.
Keith Pratt
November 19, 2010 at 11:24 pmTheir inability to play the video has absolutely nothing to do with it being PAL. It’s ProRes that’s the issue. So either they need to fix their inability to play ProRes or you need to send them the video in another codec. You could try H.264 or Motion JPEG. But don’t change the frame rate or resolution.
Christopher Martin
November 19, 2010 at 11:26 pmthanks Keith — I sent it to them in h264 30fps and h264 25 fps. one of them worked!… praise be
