Activity › Forums › DaVinci Resolve › Euphonix/Avid MC color
Posted by Ronen Pestes on July 20, 2011 at 4:28 amIs anyone here using the Euphonix/Avid MC color with the Resolve?
I am testing one of the control panels but am having issues with the trackball sensitivity.I am currently running resolve on Mac V.8.0 on OS 10.6.8
MC color Firmware 1.1.7 with Eucontrol 2.6.0.Any help will be appreciated,
Ronen
Ronen Pestes
Editor and Finishing Artist
https://www.ronenpestes.comSascha Haber replied 15 years, 2 months ago 6 Members · 9 Replies -
Dwaine Maggart
July 20, 2011 at 4:45 amHave you tried adjusting the panel sensitivity controls in the Config / Settings tab?
Dwaine Maggart
Blackmagic Design DaVinci Support -
Ronen Pestes
July 20, 2011 at 5:13 amI did try both in resolve and on eucontrol. With no luck. However, I did not see specific trackball controls. Am I missing something here?
Ronen
Fred Fleureau
July 20, 2011 at 5:32 amConfig/Settings … right botton of your gui : Lift RGB Balance sen …. Gamma RGB Balance sen …. Gain RGB Balance sen …
Apply then back in your Color tab and test your trackball
Ronen Pestes
July 20, 2011 at 10:24 amreinstalled the drivers and it is working better.
I do need to push the sensitivity all the way to the 90 zone to get it moving. The Gamma RGB need to be on 98-99 to get a nice flow. while LIFT and Gain are on 93/90.
Thank you,
Ronen
Quico Encinias
July 20, 2011 at 6:04 pmThats really odd. I found 50 to be too sensitive. Ive set mine to 30 and that is comfortable.
Ronen Pestes
July 20, 2011 at 7:13 pmQuico, that is very interesting. Even in 90 it just feels not as smooth as it should be.
which version of EuControl/Firmware you are using?
Ronen
Quico Encinias
July 20, 2011 at 8:14 pmI have the same specs as you said above.
Not sure what else could be different. You are apple tabbing so that Eucontrol and Davinci are the top 2 apps? its only thing i can think of. -
Teo Rižnar
July 21, 2011 at 12:50 pmAnother question about MC Color… did anyone found a soulution to show tabs with MC COlor, not mouse?
On JL Cooer you have an option to clic a button that opens the Qualifier, Window, Blur, Key tabs…An example of use:
On a first node I am doing a power window and “Window” tab is active, I add a new node and pull of key, I like to set key without mouse, so I just select highlights in all hue values… But I like to se the “Qualifier” tab, when doing this. Is there a way to call up a function that shows a “Window” and “Qualifier” tabs?Thank you for replays!
Teo
Color grade reel: https://vimeo.com/15480583
Cofounder of https://nuframe.si postproductionSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Sascha Haber
July 22, 2011 at 10:01 amThis might be a “limitation” of the cheap third party panels.
I totally agree, it would be very very useful.
Especially because the navigation on both small panels is very cumbersome.
I would like to see a bidirectional way, when clicking a curve , the panel should jump to the curve tab, and when using the menu navigation on the panel, the UI should update.
By the you would not have to look down to the panel all the time.A slice of color…
DaVinci 8.0.1b3 OSX 10.6.8
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE
