Activity › Forums › Storage & Archiving › Ethernet SAN solution
  • Ethernet SAN solution
    Posted by Trevor Schrodt on July 23, 2013 at 6:48 pm
    I’m researching gigabit ethernet SAN solution for our small shop with two full-time editors and one part-time. We use Macs with CS6 (CC very soon) and Resolve, AVCHD & ProRes4444 are our primary codecs with a little Canon 7D every once in a while. We don’t pull more then 2 streams per suite at a time on a regular day. We will also be upgrading to the new MacPro’s when they are released. I’ve talked with Coraid, Small Tree, & Pro Max and all seem like very good options. I was hoping to get some user feedback and pros/cons of each company/system. Any other companies I should check out? Any help is appreciated.
    Thank you for your time.
    Trevor
    MacPro 6 core – 10.8.4 24GB RAM
    MacPro 4 core – 10.8.4 16GB RAM
    MacPro 2 core – 10.6.8 9GB RAM
    Alex Gerulaitis replied 13 years, 1 month ago 7 Members · 15 Replies
  • 15 Replies
  • Alex Gerulaitis
    July 23, 2013 at 8:01 pm
    Hi Trevor,
    Could you elaborate on that Resolve codec? I think Resolve works with a number of codecs but likes to work with raw still frame ones like DPX and CinemaDNG? That might be taxing for most shared storage solutions.
  • Trevor Schrodt
    July 23, 2013 at 8:06 pm
    Sorry, that comma was supposed to be a period. We use Uncompressed QT in Resolve.
  • Alex Gerulaitis
    July 23, 2013 at 8:18 pm
    [Trevor Schrodt] “We use Uncompressed QT in Resolve.”
    If I am not mistaken, Resolve only works with one stream at a time? So we’re looking at one uncompressed QT stream per user, or two of any of the other ones, correct?
    What’s the bitrate and resolution of the uncompressed QT stream?
  • Trevor Schrodt
    July 23, 2013 at 8:33 pm
    around 1355 mbits/s & 1920x1080p
  • Alex Gerulaitis
    July 23, 2013 at 8:53 pm
    Thank you – that more or less defines the requirements. All the companies you mentioned are great choices.
    SNS Evo is another possibility and so is GB Labs Space.
    Anyone I am forgetting?
    A client of mine in Los Angeles runs a 10GbE NAS from COTS components using xServe (for the NAS OS part of it), ProAvio DAS, NetGear 10GbE switch and Small-Tree 10GbE cards. Is this something you might be interested in hearing about, or would you prefer to have a single supplier solution?
  • Trevor Schrodt
    July 23, 2013 at 8:58 pm
    We’re looking for a single supplier solution. Thank you for the help & I’ll give those companies a call.
  • Bob Zelin
    July 24, 2013 at 1:31 pm
    https://forums.creativecow.net/readpost/197/859515
    if you read through this thread, you will see the companies (including the ones that I missed) that make excellent shared storage systems.
    Bob Zelin
    OK, this is the NAB2013 list of people that know what they are doing (and I am sure I am missing a few companies) –
    Accusys Exasan (Infiniband solution)
    Apace Systems (1gig and 10gig solutions)
    Apple XSAN using Promise VTrak drives (Fibre SAN solution)
    AVID ISIS 5000 (1gig and 10gig solutions)
    Cal Digit SuperShare (Infiniband solution that requires XSAN,
    MetaSan or Command Soft Fibre Jet)
    EditShare (1gig and 10gig solutions)
    Facilis Terrablock SAN (1gig and 10gig solution, and Fibre Channel)
    GB Labs Space
    Maxx Digital Final Share (1gig and 10gig solutions – NAS)
    ProMax Platform (1gig and 10gig solutions – NAS)
    Rorke Data (using Command Soft Fibre Jet – Fibre Channel SAN)
    Small Tree Titanium (1gig and 10gig solutions – NAS)
    Studio Network Solutions EVO 5 (Fibre SAN, 1gig and 10gig iSCSI)
    Tiger Technology MetaSAN (software only SAN)
    Tiger Technology MetaLAN (NAS software)
    Tiger Technology Tbox (Fibre, 1gig, 10Gig solutions)
    Nearline storage solutions –
    Drobo
    QNAP
    Synology
    Tolis Group Argest
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Bob Zelin
    July 24, 2013 at 1:32 pm
    ps – Coraid is not on that list. It will not do what you want.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Trevor Schrodt
    July 24, 2013 at 2:05 pm
    Thank you for the info. I really appreciate it.
  • Eric Newbauer
    July 24, 2013 at 2:40 pm
    Alex/Bob, thanks as always for the mentions!
    Trevor, in addition to our EVO storage system (now also available in an 8 bay, which might be perfect for you), if you already have some direct-attach RAID storage you could try our software-based solution, which turns your existing RAID and a Mac into an Ethernet/iSCSI SAN. I’m suggesting this because you can try it all for free just by downloading it to see if it meets your needs.
    Here is the software that turns your Mac into a SAN server (Xtarget):
    https://www.studionetworksolutions.com/globalsan-xtarget/
    And here is the software you use to share the SAN storage (iSANmp):
    https://www.studionetworksolutions.com/sanmp/
    Eric Newbauer
    Studio Network Solutions (SNS)
