Activity Forums Apple Final Cut Pro Legacy Estimated Export Size??
  • Estimated Export Size??
    Posted by Christopher Bagnall on January 22, 2006 at 1:21 am
    Is there a way to find out the size of the file before exporting? It seems to be a lot of trial and error with different combinations for exporting using QT Conversion when I really need to find out the size before I spend 15-20 minutes exporting. Thanks
    Christopher Bagnall replied 20 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    January 22, 2006 at 2:34 am
    Nope, no way to tell this. Compression, frame rate, length of project all factor into the file size. Unless you’re really good at math and do a little trial and error to know how big a file is if it is 10 min long with a certain compression, and if it is an hour. But there are too many factors really.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Jeremy Garchow
    January 22, 2006 at 2:49 am
    Two ways:
    Use compressor and find the file size in the “estimated file size” dialog.
    Use math. Check your data rate and multiply. If your data rate is 800 kilobytes/sec, then multiply 800*# of seconds of your program. If it’s 5 mins long then it’s 800*300=24000 kilobytes. Divide by 1000 to get the # of Megabytes. 24000/1000=24 Megabytes. Add several more MBs for audio.
    This should get you close.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • David Roth weiss
    January 22, 2006 at 2:59 am
    Christopher,
    Check out the conversion Widget from http://www.digitalheaven.com. It might help you unless you’re exporting MPEGs, that’s a horse of another color.
    DRW
  • Christopher Bagnall
    January 25, 2006 at 4:40 am
    Thanks guys.
