Activity › Forums › Storage & Archiving › eSata Problems with than 2 esata connections – Mac Pro
  • eSata Problems with than 2 esata connections – Mac Pro
    Posted by Errol Lazare on December 15, 2012 at 6:53 am
    I have 2 Newertech esata cards in the back of my macpro 8 core. My ideal setup is 2 hard drive docking stations connecting into the 2 ports of the 1st esata card and an OWC Mercury 12TB Raid connecting into the 2nd esata.
    The Problem.
    My computer only seems to accept a maximum of 2 esata devices at once. If I plug a 3rd device in, the hard drives all other hard drives un mount and then I am given the message that the devices were not ejected properly.
    Any solutions to this?
    Errol X. Lazare
    EXL Films
    http://www.exlfilms.com
    David Roth weiss replied 13 years, 9 months ago 4 Members · 10 Replies
  • 10 Replies
  • Rainer Wirth
    December 15, 2012 at 2:36 pm
    First of all,
    what esata cards are you using inside yout Mac Pro, and how many esata outputs are on each card. What internal slots (inside MacPro) do you use (4x,8x,16x). Are the esata cards on two seperate slots?
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Rainer Wirth
    December 15, 2012 at 2:52 pm
    My guess is,
    that you use a PCIx slot x4 withg two esata devices. You need at least a x8 slot for two esata devices on one card, or you use the x16 slot for two esata devices attached to one card.
    Can you configure your PCIx slots into 3 times x8 slots (depends on your 8core mac pro)?
    This would be your best solution.
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Rainer Wirth
    December 15, 2012 at 2:56 pm
    My guess is,
    here is the link: https://eshop.macsales.com/item/Newer%20Technology/MXPCIE6GS2/
    look for “Compatibility”
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Bob Zelin
    December 15, 2012 at 4:46 pm
    excellent conclusion Ranier !
    If this gentleman had purchased this product, and not been such a cheap S.O.B., he would not be experiencing this problem –
    https://sonnettech.com/product/temposatapro6gbpcie.html
    Bob Zelin
  • Errol Lazare
    December 15, 2012 at 7:28 pm
    Hello Rainer,
    I have 2 of these cards in my system at the moment so a total of 4 esata ports. Based on what you have mentioned does the slot number make a difference in performance and utilizing different hardware? Here is what my configuration looks like in order as displayed on mac system report.
    Slot 1 ATI Radeon HD 5770 – Display Controller – Yes Driver installed
    Slot 2 Quadro 4000 – Display Controller – Yes Driver Installed
    Slot 2 NVDA, Parent – No Driver not installed
    Slot 4 pic1b4b,91a4 – IDE Controller – No driver not installed
    Slot 4 pci1b4b,9123 – AHCI Controller – Yes driver installed
    Slot 3 pci1103,622 – Raid Controller – Yes driver installed
    Let me know if this make sense.
    Cheers,
    Errol X. Lazare
    EXL Films
  • Rainer Wirth
    December 15, 2012 at 8:28 pm
    Whant bandwidth are slots 2,3,4. It depends on your mac!
    Normally slot 2 and 3 are 4x, slot 4 should be 16x.
    So, I would put the esata card, which takes 2 devices on Slot4 and the esata card with one device on Slot 3 or 2.
    But your pcix slots may be different.
    Cheers rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Rainer Wirth
    December 15, 2012 at 8:30 pm
    yeap Bob,
    but this doesn’t help our friend.
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Bob Zelin
    December 16, 2012 at 4:23 pm
    well Ranier, we are both wrong. If this gentlemen has an ATI 5770 in his computer, this means that he has an Apple Mac Pro Westmere Model Identifier 5,1. This means that slot 1 and slot 2 are fixed at x16 lanes (the ATI card and the NVidia Quadro 4000), and slot 3 and slot 4 are both fixed at x4 lanes. There is no expansion slot utility function for a 3,1 4,1 or 5,1 Mac Pro, which means that he cannot change the lane assignment on his slots.
    While I dont’ have a stright answer for him, the EASIEST suggestion is to remove the dual 2 port cards, and purchase a single 4 port card from Sonnet Technology, as I have listed, put it into a x4 lane slot (slot 3 or slot 4), and everything will work fine. I have used the exact NewerTech 2 port card that he has (just one at a time) and it works just fine in the Mac Pro.
    So Errol, what Mac OS are you running, by the way ?
    Bob Zelin
  • Rainer Wirth
    December 17, 2012 at 4:25 pm
    yes, Bob
    replacing the card is the easiest and cheapest option.
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • David Roth weiss
    December 30, 2012 at 9:49 pm
    Bob,
    I think the two cards simply conflict with one another. I’ve seen the same behavior with many inexpensive controller cards such as those from both FirmTek and OWC.
    DRW
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
