Activity Forums Apple Final Cut Pro Legacy eSATA PCI Cards
  • eSATA PCI Cards
    Posted by Kyle Macdonnell on August 9, 2010 at 2:03 pm
    Hello!
    I have a couple of Buffalo 1.5 TB drives. I’m planning on getting a new Apple desktop. Should I buy a PCI eSATA card, or stick with FW800? Some of the cards are more expensive and claim to reduce the CPU’s workload. I’m working with HD & probably CS5…
    Todd Gillespie replied 16 years, 1 month ago 4 Members · 5 Replies
  • Michael Sacci
    August 9, 2010 at 6:05 pm
    SATA is a ton faster than FW800, and the drives can be raided together to give you even faster speed. This becomes very important if you are doing multi-cam editing. Getting and enclosure also gives you huge storage space, easy to build a 10TB Raid these days.
    But SATA cards are about long in the tooth. SAS cards are more in style. They are more expensive and the enclosures are too but they give more speed and redundancy (RAID 5 as an example).
    But I do have a SOnnet E4p card that I can sell, would make you a great deal if this is what you want. COntact me off list at onthecow (at) michaelangelodv (dot) com.
  • Brandon Smits
    August 9, 2010 at 6:20 pm
    Kyle,
    I assume you mean a Mac Pro, but to be clear, iMacs do not have pci slots. Do your drives have eSATA outputs?
    8core Mac Pro Early ’08 Xeon 2.8 14gb RAM
    Apogee Ensemble
    JBL LSR 4328 Surround Set up
    Euphonix Artist Series Mc Control, Mc Mix, Mc Transport
    All wired with Mogami Cable
  • Kyle Macdonnell
    August 12, 2010 at 5:01 pm
    Hey Michael,
    Thanks for answering my questions. I might be interested in buying your SOnnet E4p card, but first I need to buy a new MacPro.
    But my question concerns the 2 external drives I already own, they are already in enclosures. Right now they are connected using the FW 800 ports, but they also have eSATA; Is it worth the $ for me to buy a pci eSATA card for my existing buffalo 1.5 TB drives, or should I just stick with the FW?
  • Kyle Macdonnell
    August 12, 2010 at 5:04 pm
    I am referring to Mac Pros that accept PCI cards & yes, the drives in question have eSATA connections…
  • Todd Gillespie
    August 12, 2010 at 9:41 pm
    Hi Kyle,
    You will definitely see a performance boast with eSata over FW 800. But depending on how Buffalo configured the drives, will determine how much of a boast.
    Good Luck,
    Todd at UCSB
    Television Production
