Activity Forums Apple Final Cut Pro Legacy eSATA Expresscard
  • eSATA Expresscard
    Posted by Josh Evans on September 5, 2008 at 12:22 pm
    Finally made the upgrade to an eSATA drive, but now I need to buy an expresscard for my macbook pro.
    I’ve read there are problems with certain brands. Does it make a difference in speed if you go with different brands?
    If so, which do you reccommend. Belkin seems to cost the most, does that make it best?
    David Wheeler replied 17 years, 9 months ago 10 Members · 20 Replies
  • 20 Replies
  • Rafael Amador
    September 5, 2008 at 12:37 pm
    I have the aCie and works great.
    rafael
    http://www.nagavideo.com
  • Walter Biscardi
    September 5, 2008 at 12:41 pm
    Does the drive manufacturer recommend a card? That’s where I always look first because if they do, that means they’ve probably tested it out with their product.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Bob Pierce
    September 5, 2008 at 12:48 pm
    I recently bought a Sonnet from Other World Computing for $100. Drives were spontaneously unmounting, and after much discussion with tech support they admitted that the unit doesn’t get along with the Mac Book Pro. I exchanged it for the $140 EZ Quest, which so far is working great for me.
    Good luck,
    Bob
    Mac Pro 2.66 – 8GB memory – Mac OS 10.5.2 – Quicktime 7.4.5 –
    Mac Book Pro 2.33 Duo –
    FC Studio 2 (Final Cut 6.0.3) – Kona Lhe
    Adobe Production Suite CS3 –
    Sony Multiformat 14″ – Panasonic 42″ Plasma –
    Ikegami HLDV7 – PVW EX-1
  • Rafael Amador
    September 5, 2008 at 1:19 pm
    Hi Bob,
    I bought two Sonnet FW-Express cards for my MBP, and no way to make them work.
    Rafael
  • Robert Buncher
    September 5, 2008 at 2:14 pm
    I have been using a Firmtek card with two Firmtek enclosures, a two bay and a five bay. It works just fine. How it might work with a different brand I can’t say.
    Bob
    MacbookPro 2.33 2gb os 10.4.11
    FCP 5.1.4 After Effects Bootcamp XPpro
  • Zane Barker
    September 6, 2008 at 2:38 am
    I’ve done a LOT of research and looking myself, and have learned that ALL eSATA card that connect to a MBP use the same chipset and same driver.
    Sure some manufacture bundle that driver inside there own installer, but after looking at the package contents of the drivers for over a half dozen cards, I found that they all used the same driver, and thus the same chipset in the eSATA card itself.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Paul Dickin
    September 6, 2008 at 10:50 am
    Hi
    Did your research identify any don’t/don’t/don’t ones?
    (Work/use same chipset/same driver)?
  • Josh Evans
    September 6, 2008 at 8:46 pm
    Hi THere,
    thanks for all the replies.
    I went with the APIOTEK EC-0003D
    it cost me $400 Hong Kong and seems to work fine. There were a few glitches at first like FCP frezing and causing bad crashes, but now seems to work ok, not sure why.
    Everything is definitely faster than before with Firewire 800. Ive noticed more things are in realtime in my timeline now, and rendering takes much less time, so eSATA definitely worth it. eSATA II must be even better, but out of my price range at the moment.
  • Jeremy Garchow
    September 6, 2008 at 9:23 pm
    [Bob Pierce] “I recently bought a Sonnet from Other World Computing for $100. Drives were spontaneously unmounting, and after much discussion with tech support they admitted that the unit doesn’t get along with the Mac Book Pro.”
    Say wha? I use a Sonnet Express 34 with an F2 for all of my portable editing/live captures. It works swimmingly. Are you sure it was Sonnet tech support you were talking to?
  • Jeremy Garchow
    September 6, 2008 at 9:25 pm
    [Rafael Amador] “I bought two Sonnet FW-Express cards for my MBP, and no way to make them work. “
    You have to be on Leopard for the fw cards.
