Activity Forums Apple Final Cut Pro Legacy eSata and playing the final cut pro timeline
  • eSata and playing the final cut pro timeline
    Posted by Max Leto on September 25, 2010 at 12:22 am
    I have an eSata G-Tech drive connected to my MBP. When I press the spacebar to play the footage in the timeline, the system is very slow to respond, and the spinning beach ball appears for 3 to 5 seconds, then the timeline plays back.
    Ironically my FW 800 connection to the same drive plays the timeline back with no problem.
    I thought eSata was %200 faster then fw 800. Any ideas of what I’m doing wrong?
    Thank you.
    -M
    Christian Calon replied 15 years, 10 months ago 5 Members · 6 Replies
  • Rafael Amador
    September 25, 2010 at 5:02 am
    I bet that a bit of maintenance to your system and HDs would make everything run faster.
    Repair permissions and rebuild the directories (DiskWarrior, TechTools,..)
    rafael
    http://www.nagavideo.com
  • Roli Rivelino
    September 25, 2010 at 8:30 am
    When I bought my Mac, I put in an esata bus card so I could use my esata drive. After many months and many days being driven close to tears and madness, I gave up.
    No one could explain why it didn’t work (using the esata triggered a kernel failure and made my machine crash) the machine went back to the shop 3 times to no avail, I decided to give up before I turned into a bitter, raving-I told you PCs were better-lunatic, I advise you do the same and just stick with FW800 it’s still fast and like you say it works.
    Good luck with it all.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Rafael Amador
    September 25, 2010 at 8:42 am
    [Roli Rivelino] ” I advise you do the same and just stick with FW800 it’s still fast and like you say it works.”
    I say the opposite.
    Go e-SATA.
    Your bad luck, Roli, doesn’t justify that advise.
    You won’t read many complains about e-SATA in this forum.
    rafael
  • Shane Ross
    September 25, 2010 at 9:29 am
    Could have been a bad eSATA card…or not a quality one. Not all are created equal. I have had zero issues with mine. Caldigit variety.
    Shane
  • Roli Rivelino
    September 25, 2010 at 9:55 am
    This is why I refer to my Mac as Schroedinger’s Mac, because sometimes when you turn it on it works properly and sometimes not. The guy who sold me the esata card said he’d sold loads all without complaint so rather than depress myself further I felt it best to turn my back on esata; shame.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Christian Calon
    October 25, 2010 at 2:12 am
    yes, probably your drives need permissions repaired.
    I just started using the Sonnet eSata Pro card with my MacBook Pro 2,5 GHz. Compared to FW800 it is over 5 times as fast. And not one glitch.
    MacBook Pro 2,5GHz, 4GBram, eSata G-Raid nTB, dual 23″ monitors, FCS3, Modul8… Nuendo 4/ Live/Reaktor 5/Euphonix/JLCooper/Motu i/o/2 G4 PowerBooks/multichannel surround audio setup.
